Old 09-05-2013, 06:08 PM   #1
longblue72
Active Member
Huge battery drain issue
Just recently I've started to have a big drain of my battery. I'll say this first, its a brand new battery, I've went through three alternators. ( two were remanufactored incorrectly from advanced and one is a one wire) thinking that my alternator wasnt doing its job. But the one wire is and with a DVOM it shows the battery charging around 13.5 volts.
My main Question to try and solve this battery drain issue is what have you guys found that gave you this problem? Is there something that seems to keep coming up with everyone? Things to check first? Any help is greatly appreciated because this is my daily, and its really frustrating having the battery be stone cold dead after one day of work each day.
longblue72 is offline   Reply With Quote
Old 09-05-2013, 06:27 PM   #2
Bigdav160
Bigdav160's Avatar
Re: Huge battery drain issue
To discharge a new battery overnight is going to require around a 5 amp drain.
That is significant. With the little bit of electrical equipment these truck have you should be able to see it. Something like the brake lights staying on, a stereo+amp not powering down, or possibly a horn that is stuck on that is also bad so it doesn't make a sound.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-05-2013, 06:32 PM   #3
longblue72
Active Member
Thanks for the fast reply. Yeah it is tremendously fast. And its dead to the point where my dome light doesn't light up.
Old 09-05-2013, 06:40 PM   #4
cleszkie
cleszkie's Avatar
You said that you used a one-wire alternator so I'm assuming that it was an internally regulated unit. Just confirm whether you still use a voltage regulator or not. If you do, this may be were the problem lies. They are known to cause charging and discharging issues when they go bad.
cleszkie is offline   Reply With Quote
Old 09-05-2013, 06:47 PM   #5
longblue72
Active Member
Woops, it is internally regulated now.
Old 09-05-2013, 07:33 PM   #6
truckdude239
truckdude239's Avatar
unplug your horn relay under the dash and see if it does it
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 09-05-2013, 07:48 PM   #7
Daaaanz67
Disconnect you negative battery cable. Place a test light between cable and negative post. Pull fuses till test light goes out. That will isolate which circuit is pulling current. Oh yeah the test light should glow pretty bright with that much current draw when you first hook up the test light.
Daaaanz67 is offline   Reply With Quote
Old 09-05-2013, 07:59 PM   #8
71swb4x4
71swb4x4's Avatar
Do what Dan says. I would start by unhooking the alternator. If that's the only item you have changed in this equation then it would be suspect.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-05-2013, 08:05 PM   #9
Andy4639
Old member
Andy4639's Avatar
Wink Re: Huge battery drain issue
Pull the one wire out and trade it back in for a SI alternator. Lots better in charging and a lot better all around. Follow the instructions in the electrical section.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
