Old 07-07-2003, 03:53 AM   #1
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
Question Is a C-Notch necessary?
Im think of doing a 4/6 drop on my 71 C10 Fleetside SWB. Is a C-notch necessary or recommended? I don't want to have any problems just have a nice ride. Also need suggestions on rim/tire sizes 15-16-17? Probably 15's TT2's my wife will kill me if I try to go any bigger than that.
OldSkool71 is offline   Reply With Quote
Old 07-07-2003, 08:35 AM   #2
Joe67
67 is sold
With a 6" rear drop your axle will hit without a c-notch
Joe - Formerly 67c10step
1967 Chevy Stepside - ECE 4/6, fuelcell, 5lug - SOLD
gr8lakes - My ebay auctions
Click here to order forum apparel :: Click here to become a subscribing member
Joe67 is offline   Reply With Quote
Old 07-07-2003, 09:01 AM   #3
454ss_2
454ss_2's Avatar
Yes you need one, or you will have a bent frame and broken back...from the axle hitting the frame on every bump.
90 454ss
92 454ss
00 Silverado
08 Avalanche LTZ
454ss_2 is offline   Reply With Quote
Old 07-07-2003, 01:13 PM   #4
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
thanks maybe I don't have to go that low. Im looking at this as an example..?
Old 07-07-2003, 05:51 PM   #5
454ss_2
454ss_2's Avatar
That truck and drop looks real sweet
90 454ss
92 454ss
00 Silverado
08 Avalanche LTZ
Old 07-07-2003, 05:54 PM   #6
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
that's a 4.5 front and 6.5 rear without a notch? I was told from high authority that a c-notch is not necessary? What do you think?
-Ron-
Old 07-08-2003, 01:19 PM   #7
RandysGal
RandysGal's Avatar
I wouldn't be woried about tire size tickin off the wife. I would however be worried about explaining how you bent the frame without a "C" notch with that much of a drop. And I would imagine the ride would be everything but nice
RandysGal is offline   Reply With Quote
Old 07-08-2003, 03:52 PM   #8
Dandeluxe
Dandeluxe's Avatar
c- notch ????
Does anybody have a pic. of a c- notch i need to see how this is done and is it really necessary?
1969 cst swb 350/400 th . DANNY C .
["]FRIENDS DONT LET FRIENDS DRIVE F@RD$!!
1969 cst swb corvette hugger orange with 400 hp sbc
I started out with nothing and i held on to it
Dandeluxe is offline   Reply With Quote
Old 07-08-2003, 04:12 PM   #9
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
Here is a link to a pic. Im still having trouble trying to get some pics to uplaod because of size. Still working on it.
http://www.classicperform.com/6372CNK.html
Old 07-08-2003, 08:39 PM   #10
Slammed '87
Slammed '87's Avatar
here's my old c-notch
This is my old c-notch on my '87. I dunno how different the frame's are between the year's but you get the idea. I also don't know for sure the clearance on your ride, but i know on '73 to '87's you don't have to have a c-notch with 6" drop. As long as you remove the oem bumpstop, and add a new shorter bumpstop, you will not have any problem's. Mind you on huge bump's you may bottom out, but for city/hiway use you shouldn't have a problem. BUT, seeing that c-notch's are really cheap and easy to install, i would go for it. Then at least it's done right!
Slammed '87 is offline   Reply With Quote
Old 07-10-2003, 04:06 PM   #11
1971Stepside
Almost Satisfied
1971Stepside's Avatar
I have the Early Classic Enterprise 4/6 drop on mine and I spoke with them on two different occasions about needing a c-notch. Both times they told me no way do you need a c-notch with the 4/6 drop. I didn't put one in and I think I will have to hit a very big bump or hole to get the axle to hit the rubbers.
1971 C10 Stepside. LSx 6.0 with BTR Stage IV, Speed Engineering Headers, 4L80e transmission w/3200 Circle-D Stall. 3.73. Posi. Purchased this truck when I was 17. I started the rebuild (or take apart) in 1993. I have drug it around all over the country in pieces. Finally back on the road in 2021.
"I can't complain, but sometimes I still do. Life's been good to me so far."
1971Stepside is offline   Reply With Quote
Old 07-10-2003, 04:50 PM   #12
OldSkool71
C/10 CLUB MEMBER
OldSkool71's Avatar
1971Stepside, that is what I was told as well. Did you remove the bump stops or trim them? How does it ride? Now that im looking at my truck a little closer im wondering if im gonna have problems with my headers? Damn!
-Ron-
Old 07-19-2003, 03:22 AM   #13
old gearhead
I have run a 4/6" drop for a lot of years with no problems and no c-notch. I also run really stiff shocks and drive cautiously.(not because of the drop, but because its my baby. LOL) I was concerned with frame strength, and I try never to do anything I can't undo later. Good luck, J
old gearhead is offline   Reply With Quote
Old 07-21-2003, 10:16 AM   #14
Hotrod70C10
Low & Slow
Hotrod70C10's Avatar
Nice thread guys, I'll keep this in mind if I decide to go with a 5 or 6 drop instead of the 4 i have now.
70' C-10 LWB Fleetside
4.5/6 drop
Hotrod70C10 is offline   Reply With Quote
Old 09-16-2014, 01:41 PM   #15
Coursey
Coursey's Avatar
Re: Is a C-Notch necessary?
Which route did you decide to go and how does it ride?
Coursey is offline   Reply With Quote
