Old 09-05-2013, 11:44 PM   #1
zoomie54
Master cylinder install in an AD frame
Looking pictures of brake master cylinder in a 53 AD frame. I have a 79 Camaro front end with disc brakes on the front and a 94 3:08 posi with disc brakes in the rear. I bought a new brake master to replace the original on the frame. I would appreciate any measurements and tips for the installation. Thank you in advance.
zoomie54 is offline   Reply With Quote
Old 09-06-2013, 12:18 AM   #2
mr48chev
mr48chev's Avatar
Re: Master cylinder install in an AD frame
I don't have any measurements but when I want from single to dual master cylinder I fabricated a bracket that bolted to the original two holes in the bracket off the frame that the original master cylinder bolted to.
It consists of the rectangular plate that bolts to the bracket, a piece that the master cylinder bolts to that has holes for the bolts and a hole for the pushrod and dust cover to slip through that is welded on the long piece and a gusset to strengthen it. We made a heavy duty push rod for it that is adjustable.
The master cylinder sits further back on the frame than the stock one so the pushrod has to be longer. It is set up so there is a pretty straight shot from the pedal to the master cylinder.
You want the new master cylinder centered on the arm off the brake pedal that pushes the push rod so you have as straight of a push as you can get.
My ongoing truck projects:
Old 09-06-2013, 10:17 AM   #3
MidLifer
MidLifer's Avatar
I hate to drag folks off this board to another, but I was just researching the same topic and found this excellent article on Stovebolt.com:
http://www.stovebolt.com/techtips/ma...der/index.html
The brackets can be purchased.
Does anyone know of a thread about installing a power booster on an AD truck? I've tried all the search functions on this site (native and Google) and having trouble finding one.
MidLifer is offline   Reply With Quote
Old 09-06-2013, 11:31 AM   #4
mr48chev
mr48chev's Avatar
That is a pretty slick bracket and slick setup. If a guy has an extra 100 bucks to spend and didn't already have the pedals and pedal bracket that might be the way to go.
Old 09-06-2013, 12:45 PM   #5
torchlight
torchlight's Avatar
Here's what we ended up doing on mine. Sorry, these pictures aren't the very best, but I think you can get the idea. We ended up mounting the MC and booster on the outside of the (stock) frame and running a linkage through the frame for the brake pedal. Did this so there would be plenty of room for the headers and exhaust to come through - was really very tight with the MC inside the frame.
Here you can see the linkage through the frame to the right of the front suspension. Gives you an idea where this is located on the truck:
Closeup of the linkage and the mounting plate for the booster:
Here's the whole assembly, hiding under the cab, outside the frame, just behind the front running board bracket:
Another view:
You can see the linkage here again, running over the driver's side header. Also how nice it is to have the extra room for the exhaust to come through:
torchlight is offline   Reply With Quote
Old 09-06-2013, 01:20 PM   #6
Wybrow
^ That's pretty crafty. Looks really well built, aswell.
Wybrow is offline   Reply With Quote
Old 09-06-2013, 02:56 PM   #7
mr48chev
mr48chev's Avatar
Crafty indeed, Nice work Torchlight and great thinking out of the box to make things work and still keep them fairly simple.
Old 09-06-2013, 03:00 PM   #8
torchlight
torchlight's Avatar
I can't take any credit other than saying "yes" when the guys at the shop floated the idea to me. They are really good at what they do!
Old 09-06-2013, 04:26 PM   #9
_Ogre
_Ogre's Avatar
i haven't been able to find the picture since, but someone cut the back half off their mc and gutted the mc.
then he attached a heim joint and a rod to the pedal assembly to a relocated mc, further back on the frame.
i thought it was a brilliant idea, one of those ''wish i had thought of that''
shop air compressor timer
Old 09-09-2013, 12:37 AM   #10
zoomie54
Smile Re: Master cylinder install in an AD frame
Thank you all for the great ideas and pictures. I found a three part YouTube on the installation of a master cylinder in. A 1953 Chevrolet truck. It has great pictures and narration. I am sure everyone would enjoy more ideas and pictures. Keep building and sharing ideas.
Old 09-09-2013, 12:28 PM   #11
_Ogre
_Ogre's Avatar
and your going to keep it a secret? wtf?
Old 09-10-2013, 02:29 PM   #12
zoomie54
Not a secret on Youtube address:
Zoomie54
1953 5 Window Chevy Pickup w/ 1979 Camaro front clip, 1994 LT1, 4L60E, 3:08 Posi disc rear end
Old 09-13-2013, 04:46 PM   #13
55dude
55dude's Avatar
Nice job. Do you have anymore pics inside the frame?
55dude is offline   Reply With Quote
Old 09-14-2013, 12:28 PM   #14
_Ogre
_Ogre's Avatar
zoomie; that would be a brothers bracket and kit
both are easy to make for cheap if you want to save a whole bunch of cash
