Ho-52 help
Working on my rear disk conversion, took my hubs and brakes off and found this backing shield, is this a speedy sleeve? I have never seen a Speedy sleeve with this big of a lip. I don't think i can remove the backing plates to do the conversion unless i cut this thing off???
Any advice is greatly appreciated!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Re: Ho-52 help
Looks like a dust shield. You should be able to get behind it and tap it forward till it pops off. Go slow and work it evenly. Dusts seals have a tendancy to get crooked and bent. When you reinstall it you may want to put a little loctite under it as they tend to be loose on reinstall.
Re: Ho-52 help
I'll try to tap it off, thanks for the help!
What?
Re: Ho-52 help
I agree that this is a dust shield as well.
My HO52 has it too, but I have seen other HO52's with out them.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
Re: Ho-52 help
Thanks guys, I got them off today, jyst put a heavy crows foot across the back side and was able to tap it off.
Re: Ho-52 help
New question for everyone:
My rear hubs have been running Barrel roller bearings for the last 41 years, i popped the bearings out last night and then opened up my new bearings to check the size and found them to be tapered roller bearings, Any cause for concern?
What?
Re: Ho-52 help
Mine are tapered.
No idea if barrel style is OK for this application you have, but if you do use them be sure to replace the races. Which is the rule when replacing roller bearings anyway.
Re: Ho-52 help
Still looking for answers on my last post please.
I didn't clarify that i have a full floating rear axle, its has always had barrel bearings and the auto parts store gave me tapered roller bearings, can i interchange? Are all the HO-52-s the same? Vectorit's are tapered but i don't know if he has a full floating axle. Thanks!
What?
Re: Ho-52 help
Pretty sure all HO-52 and 72's are FF
Re: Ho-52 help
>>>>>> its has always had barrel bearings and the auto parts store gave me tapered roller bearings, can i interchange?<<<<<<
This is my question..
What?
Re: Ho-52 help
I'm no expert, but I don't see why not if you change out the races.
