Old 09-06-2013, 12:13 PM   #1
willett
Another Day, Another Dollar
willett's Avatar
Alternator wiring routing and gauge question
Hey guys,
I'm in the last steps of having my k20 ready for 4x4'in season. Today's job is to put a shiny new 110A alternator on there (I need it because I have dual batteries, a stereo, and enough lights to illuminate Yankee stadium)
Anyhow, whatever is on there now is a 3 wire setup
The new alt can be 1 or 3 depending in wether or not there is a jumper in place.
My questions:
1. should I bother running 3 wire setup? I have no charging light and do I really need the sensing wire?
2. Will 4 ga wire be sufficient? ( I'm going to run 2/0 from the starting battery to the starter mostly because I have some laying around)
3. Should I run the charge wire from alt down to the starter or just T it and run it to both batteries? ( I will be putting an ignition controlled solenoid between battery 1 and battery 2 but that's for a different day)
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box
"its hip to be square"
willett is offline   Reply With Quote
