Old 09-06-2013, 12:37 PM   #1
dazza
dazza's Avatar
a few extra opinions before the hacksaw hits NOS parts...
After checking and rechecking I'm 90% sure the pins on the new door handles have to be shortened to function correctly.
Just like to confirm if anybody happens to know before I get to cutting!
I'm not crazy, I'm chosen, there's a difference.
'72 K10 SWB, 350, sm465/np205
dazza is offline   Reply With Quote
Old 09-06-2013, 12:52 PM   #2
BrianG
BrianG's Avatar
Re: a few extra opinions before the hacksaw hits NOS parts...
do you mean just the pin? can you get a picture with both the new and old facing the same way? I'm thinking that they will work as is, but maybe I'm not sure what you are thinking will have to be trimmed.
BrianG is offline   Reply With Quote
Old 09-06-2013, 01:42 PM   #3
dazza
dazza's Avatar
Basically the plate where the pin starts is the red line. and although it's difficult to see from the pic, when I line them up, the new one would have to be cut at the line(blue arrow) that is formed into the pin, almost as if it was scored for this purpose. cutting it there would make them almost the exact size.
Old 09-06-2013, 01:47 PM   #4
TBONE1964
Cluster King
TBONE1964's Avatar
Have you tried installing the NOS one on the truck yet? I would not cut it unless you absolutely had to. You will notice that the latch lever does move a lot before it "pops" the door open.
I would try installing it and just be easy. I have never seen one that needed cut especially NOS.
TBONE1964 is offline   Reply With Quote
Old 09-06-2013, 02:13 PM   #5
dazza
dazza's Avatar
I did install it but it wouldn't fully lock. From what I could tell, the plate that the pin pushes against wasn't able to completely move to where it should be because the pin was stopping it. Almost like it was being pressed in half way all the time.
Old 09-06-2013, 02:15 PM   #6
dazza
dazza's Avatar
Going to check factory assembly manual and see if it shows anything.
Old 09-06-2013, 02:16 PM   #7
TBONE1964
Cluster King
TBONE1964's Avatar
Well in that case, you may have to trim it a little. I would do it in baby steps so you don't take to much off.
Old 09-06-2013, 02:21 PM   #8
lolife99
67-72 parts collector,…
lolife99's Avatar
I had to cut my handle pin to make it work.
Keith
Convert to disc brakes.
Old 09-06-2013, 02:35 PM   #9
dazza
dazza's Avatar
yea, it's as if that scoring was put there for a reason. I wonder if there was another year that used the full length.
Keith, were yours NOS or repops?
Old 09-06-2013, 02:43 PM   #10
lolife99
lolife99's Avatar
Keith, were yours nos or repops?
nos
Passenger side only.
Keith
Old 09-06-2013, 04:44 PM   #11
uncle
I think it's made that way for rear doors on sub and panel. I think they need longer tab. I THINK!
uncle is offline   Reply With Quote
Old 09-07-2013, 12:01 AM   #12
71 super
71 super's Avatar
You have to cut for trucks longer for subs, as Tim said
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
