Old 09-06-2013, 06:25 PM   #1
Andy4639
Old member
Andy4639's Avatar
Question AC/Cooling fan
I installed this relay under the hood a few month's ago. It has worked fine up until last week. It will work for a little while then it just quit's. I can cut it off and back on and it will run again. It's a 12v 30amp relay. I wired it off the compressor so when ever the compressor is running so is the electric cooling fan in front of the radiator. Wondering if I can hookup another AC factory relay in place of this one are find a real heavy duty relay.
Any thoughts on how to wire the factory relay.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
