09-06-2013, 07:42 PM | #1 |
Weak Brake Pedal
I am having trouble with the brakes on my brother's 1969 GMC C15. The truck stops but the brake pedal soft and under hard braking the wheels don't lock up. I have replaced the master cylinder and the rear left wheel cylinder (busted bleeder valve). I also swapped out the portioning valve with an old one I had lying around. The rear shoes and drums looked good. I believe the rear brakes are not getting the correct amount of pressure. When I bled the brakes the front cylinders shot out a stream of fluid but the rear cylinders only dribbled out. Is there something that could be causing this?
1971 Chevy C10 Cheyenne (sold for Mazda) 1963 Chevy Corvair Pro-Touring Project 2012 Mazda 3 i Sport sedan http://www.dracoautodesigns.com/ |
09-06-2013, 07:48 PM | #2 |
Re: Weak Brake Pedal
that truck should not have a proportioning valve// it had a distribution block from the factory which is completely different
09-06-2013, 08:40 PM | #3 |
That explains a lot. I was wondering why a drum/drum truck would need a portioning valve.
