Old 09-06-2013, 08:21 PM   #1
Rusbuilt
Rusbuilt's Avatar
Any one running manual brakes with an LS swap?
Just curious if anyone is doing this. Thanks
Rusbuilt is offline   Reply With Quote
Old 09-06-2013, 10:12 PM   #2
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
Re: Any one running manual brakes with an LS swap?
I thought about it when my vacuum was lower. Now its better but still considering swapping to a slightly smaller dual booster.
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 09-07-2013, 12:16 AM   #3
crazy longhorn
Fabricate till you "puke"
I run a manual disk/drum on my longhorn, also stick shift. The old truck is in the mid of an LS swap, so I cant be of much help on any questions tho... Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-07-2013, 01:03 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Yes I was running a manual Disc/drum setup with my lq4. I was even running that setp with the big D52 Wilwood's in the front.
What do you want to know exactly?
You need to run a prop valve, it doesn't lockup the brakes really well, and it made may knee and thigh hurt....Oh and if you ever try to take it down a dragstrip, you'll bend the steering wheel at the big end the first time you try and stop it from 100+mph
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-07-2013, 03:48 AM   #5
crazy longhorn
I haven't had too many issues stopping my old truck? The complete system came from a 75 C-10 donor....stick shift helps tho (the power brake option is in my right hand) Any time I have had to haul her down quick, I would just shift down a gear or 2 & let the clutch up Normal driving in traffic doesn't seem to be any issue, but I will agree that you will have your hands full, trying to stop that manual brake setup from 100+ mph! Longhorn
Old 09-07-2013, 07:07 PM   #6
Rusbuilt
Rusbuilt's Avatar
Thanks for the info guys. BR3W CITY you answered all of my questions. I really like the cleaner look of not having a booster and I was just curious of how the set up felt. Thanks again
Old 09-07-2013, 08:43 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I understand the concern in terms of engine cluttering. If you want SUPER clean you can look at the small diameter vacuum "designer" units from Wilwood and the like, but they are spendy.
I've got the hydroboost now, and although its got a ton of clutter, I can lockup the front wilwoods and the rear drums on those steamroller wheels I have, without much issue (though the system does need some fine tuning).
Old 09-14-2013, 08:05 PM   #8
softballnrd27
Always a work in progress
softballnrd27's Avatar
They sell kits to move the booster under the dash.
USMC Retired
Never trust a man who can't laugh at his own fart!
2010 Silverado Crew Cab
73 SWB 5.3/4l80e
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=695168
softballnrd27 is offline   Reply With Quote
Old 09-15-2013, 02:05 AM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
For hydroboost? That sounds like a freakin nightmare. Hot hydraulic fluid being pumped into my cab sounds like something I want to avoid.
Old 09-15-2013, 07:07 AM   #10
Rusbuilt
Rusbuilt's Avatar
I'm pretty sure he's just referring to relocating the vacuum brake booster under the dash. As far as I know they don't make a kit that just relocates the booster only, I think you have to move the master cylinder too. Which I don't want inside the cab.
Old 09-16-2013, 10:52 AM   #11
Hart_Rod
Hart_Rod's Avatar
I'm running disc-disc (13"/12") with a CPP MCPV and have no problem stopping.
Hart_Rod is offline   Reply With Quote
Old 09-16-2013, 08:10 PM   #12
Rusbuilt
Rusbuilt's Avatar
Thanks for the info Rob! I appreciate it.
Old 09-17-2013, 11:36 AM   #13
shearjs
shearjs's Avatar
I also have disc/disc with a manual Wilwood M/C. My hydroboost was leaking fluid around the pushrod so I just swapped to manual for the cleaner firewall look. I should have my truck in town in the next few weeks. When I finally get it here, I'll swing by the shop if you'd like to check it out.
shearjs is offline   Reply With Quote
Old 09-18-2013, 06:50 AM   #14
Rusbuilt
Rusbuilt's Avatar
Thanks Jason! I'd like to see it for sure!
