Old 09-06-2013, 11:03 PM   #1
swamp rat
swamp rat's Avatar
carrier removal
I read one threads where a guy pulled the diff assy out of his dana 44 to change the inner seals and said it was ok as long as you put the carrier bearing retainor caps back on the same sides. I understsnt all about the contact pattern and its importance. I would like to change the seals too. Is it ok to do this leaving the pinion alone and not fear the contact pattern being messed up? Is there any shims to worry about?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-07-2013, 12:23 AM   #2
76k10
Re: carrier removal
I pulled the chunk out of my 44 to do inner seals about a year ago. Threw it back in exactly as it came out and I've have no issues.
76k10 is offline   Reply With Quote
Old 09-07-2013, 11:47 AM   #3
mjensen
mjensen's Avatar
Re: carrier removal
As long as you pay close attention to how you pull it apart. Caps and shims MUST go back on the same sides. It should be good.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 09-07-2013, 12:31 PM   #4
Bigdav160
Bigdav160's Avatar
Re: carrier removal
Do not worry. The disassembly/reassembly you're proposing, will not change any adjustments
But the caps must go their original side and orientation. Mark them somehow. I usually use a center punch.
The side shims on a Dana 44 are under the bearing. You cannot mix them up by removing the differential case. The case should be tight in the housing (carrier). Proper procedure with a Dana is to use a spreader to get the case and ring gear back in.
The pinion depth shims are under the bearing race. The pinion bearing preload is also done by shim and not a crush collar. So removing the pinion doesn't cause any worry about adjustments.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 09-07-2013, 12:38 PM   #5
swamp rat
swamp rat's Avatar
Re: carrier removal
I read this late last night, now I'm concerned that if i am successful at pulling it out that I'll have trouble putting it back in without this spreader tool, have you done this without the tool??
thanks for the words on the shims too, that was part of my concern
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-07-2013, 12:45 PM   #6
swamp rat
swamp rat's Avatar
Re: carrier removal
Just found this with a Google search:
http://www.pavementsucks.com/tech-article-3.html
Can anybody tell me how heavy the carrier is?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-07-2013, 01:34 PM   #7
Bigdav160
Bigdav160's Avatar
Re: carrier removal
An open ring gear and case (I'm a stickler for terminology) weighs, maybe. 10 lbs.
I don't know if your axle is installed in the vehicle but, I seem to remember, it will not come out without disconnecting the steering link.
My Classics:
'73 Z-28 Camaro
'50 Ford Coupe
Old 09-07-2013, 08:53 PM   #8
LONGHAIR
Re: carrier removal
You do not need the case spreader for a Dana44. That is a Dana60 thing. The 44's carrier should come out with a bit of prying.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 09-07-2013, 10:55 PM   #9
swamp rat
swamp rat's Avatar
Re: carrier removal
How big a pry bar? And again can a guy do this by himself? Thanks
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-07-2013, 11:13 PM   #10
birdistheword
birdistheword's Avatar
Re: carrier removal
If you would like some help I live right on base next to you.
Erik
1969 Chevy K20 6.0L/4L80E/NP205
1971 Chevy C30 Cheyenne Longhorn 454/TH400
1979 Chevy K30 dually currently in pieces
birdistheword is offline   Reply With Quote
Old 09-07-2013, 11:14 PM   #11
fp1967
fp1967's Avatar
Re: carrier removal
Yes, it's pretty easy to handle by yourself on a Dana 44.
fp1967 is offline   Reply With Quote
Old 09-08-2013, 02:37 PM   #12
swamp rat
swamp rat's Avatar
Re: carrier removal
Well i got it out, just hope to hell i can get it back in again tomorrow! LOL! Axle tubes are cleaned and the seals are installed.
As for the next 6 hoiurs, the sun is out and the wife wants to go to the fair and being as she bought tickets i better oblige or i'll be in the dog house.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-08-2013, 02:38 PM   #13
swamp rat
swamp rat's Avatar
Re: carrier removal
Birdistheword if i have troubles tomorrow i'll contact you.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-09-2013, 05:06 PM   #14
swamp rat
swamp rat's Avatar
Re: carrier removal
Thanks everyone for the help, I got it out yesterday, cleaned out the tubes and installed new inner seals and put it back in this morning.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
