Old 09-07-2013, 10:16 AM   #1
Niteshade
Do I have a rear end problem?
Yesterday I put my 54, with a 12 bolt rear end from a 70's Camaro up on jack stands to begin disassembly. When I put the lug wrench on the lug nut to remove the rear tire, the wheel rotated freely even though the Turbo 350 was in Park. Turning the wheels did not turn the driveshaft.
Does this mean I have a problem inside the rear end?
Niteshade is offline   Reply With Quote
Old 09-07-2013, 10:43 AM   #2
chev3600
chev3600's Avatar
Re: Do I have a rear end problem?
No problem. Thats normal for an open differential. It's easy to bust them loose while its sitting on the ground, then jack it up.
1949/1954 with LS swap-yeah!
http://s260.photobucket.com/albums/i...0/AD%20trucks/jumbled mess of unorganized photos
chev3600 is offline   Reply With Quote
Old 09-07-2013, 11:32 AM   #3
mr48chev
mr48chev's Avatar
Yep, that's normal, You can either set the park brake or break them loose before you jack it up. I'd hate to count the number of times I had to let one of mine back down to break the lug nuts loose and jack it back up.
You could have had a helper push the brakes so you could break the nuts loose though.
My ongoing truck projects:
