Can I skip the crank pulley & connect directly to water pump for AC belt connection?
Thanks.
Re: Can I skip the crank pulley & connect directly to water pump for AC belt connecti
I don't think the water pump bearings would hold up.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
you could...I wouldn't.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
I knew that would be the answer. LOL.
CAN'T FIX NOTHIN
Gm made a lot of pulleys that are made to add they fit like a glove I put power steering and air conditioning on my 67 I searched and found pulleys that fit PERFECT ! Just look around on this site on ebay or junkyards they are out there ,,,,
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
CAN'T FIX NOTHIN
Pics are not great but you can see mine in this thread pulleys are 3 deep if I add any more accesories to my truck they will have to be electric lol
http://67-72chevytrucks.com/vboard/s...42#post5546642 Posted via Mobile Device
![]() Join Date: Oct 2005
It would not work. All the load would be on the belt driving the water pump. It would squeal & burn up in short time.
