Old 09-07-2013, 07:51 PM   #1
WhippinSaw
WhippinSaw's Avatar
heat riser and headers
I have a set of ram horns like in the picture below on my 327. I was thinking about replacing them with headers but was wondering what to do about the rough cold starts without the heat Riser no longer in the exhaust pipe. (I would also have to mount my alternator somewhere else.) Without the heat riser I have to flutter the gas pedal until the cold light goes out. Is there a heat riser for headers or should I just run duals out the ram horns;
WhippinSaw is offline   Reply With Quote
Old 09-07-2013, 08:18 PM   #2
LVPhotos
LVPhotos's Avatar
Re: heat riser and headers
Is that still working? I had mine rusted open and that's dry weather. Run a enclosed air filter like the 70-80 Chevy. Pipe clamp small exhaust pipe to header then flexible pipe to air cleaner. Something like my 1973 454 had just small adjustment in pipe to header.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 09-07-2013, 11:27 PM   #3
Rich 5150 69
Rich 5150 69's Avatar
You can switch to a manual choke....or just run duals off of the ram horns.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 09-07-2013, 11:58 PM   #4
luvbowties
luvbowties's Avatar
Smile Re: heat riser and headers
We've found in our area that by just enriching the choke properly, we do not have to flutter the gas pedal until engine warms up. Just start up and go--and smoothly so--until eng. warmth coincides with choke pull-off. [Of course, here in SC, we don't have as cold days as you guys; but, nonetheless, we DO see some mornings in the teens, and still no problems.] Takes a bit of trial-and-error, but it can be done! Patience and properly-operating choke will be your friends.
Sam
luvbowties is offline   Reply With Quote
