![]() Join Date: Aug 2012
Bed to cab gap
Installed the bed and the top gap is horrible and the bottom is wide. All new body mounts although the body lines look good not sure any ideas.
Posted via Mobile Device |
![]() Join Date: Apr 2007
Re: Bed to cab gap
Pics??
Build thread at http://67-72chevytrucks.com/vboard/s...d.php?t=475791 |
Re: Bed to cab gap
What year are you working on? Did you verify that the cab cushions are installed in the correct position?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Re: Bed to cab gap
1969 yes i checked the cab cushions. ill try to post a pic.
Re: Bed to cab gap
Your description indicates either the bed or the cab is tilted, can you tell which one?
The Older Generation
Re: Bed to cab gap
1/2 or 3/4 ton? The mounts are different. You sure you didn't use the wrong ones? It will take pictures to figure it out. LockDoc
Re: Bed to cab gap
1/2.ton.
Re: Bed to cab gap
Post the pic's of the part number from the kit if you can, but it does sound like possibly a 3/4T kit under a 1/2T???? Or possibly just not tightened enough or under tightened?
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
Moderator
![]() Join Date: May 2007
Re: Bed to cab gap
Frame tweaked or bed is not square? Without pics it's hard to say.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
