Old 09-07-2013, 10:03 PM   #1
kcfirstbuild
Puking antifreeze !
So this is only the second time i drove my truck after 3 long years. Today I pulled in the drive and I was puking antifreeze. It just have done so the first time since I added before I took off for the second drive. My question is, is this normal ? or do i need a different radiator cap ? or is that the level it should be after its done puking and i shouldn't add any more ?
kcfirstbuild is offline   Reply With Quote
Old 09-07-2013, 10:08 PM   #2
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Puking antifreeze !
It should be down 2-3 inches in the radiator.These trucks don't have an overflow tank from the factory.If it bothers you,do a search,many have posted their solutions.You need to check it regularly because it may go down a little at a time and need periodic refilling.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 09-07-2013, 11:04 PM   #3
kcfirstbuild
ok it was down two inches and i filled it to the top fin. I will let it rid that that depth.
Old 09-08-2013, 09:18 AM   #4
jabborabbo
jabborabbo's Avatar
When I first got my truck it would puke coolant until the level in the radiator got down about 5-6 inches below the filler cap - turns out the original owner had a 9 lb radiator cap on it and the manual calls for a 13 lb cap. I replaced the cap and it quit (provided the cold radiator was correctly filled to 2-3 inches below the filler cap).
jabborabbo is offline   Reply With Quote
Old 09-09-2013, 08:41 PM   #5
kcfirstbuild
The original AC cap was a 15psi Im sure it was original too. My murray book at work called for a 16psi. Filled it up to the top fin and put a new 16 on. Will find out this weekend what happens.
