Old 09-07-2013, 10:38 PM   #1
msblackbetty79
msblackbetty79's Avatar
frame swapping?
im hopefully going to be gettin a 2wd blazer but im wondering how are is it to swap to a 4wd rig? cause i love my 4wds.
the blazer is a 75 2wd.
I have a 79 4x4 truck frame 1/2 ton.
my question is could i chop the front half of that truck frame off and weld it onto the blazer frame? are they the "same frames" as in size and thickness? i understand the truck frame will be longer than the blazer but ill only need the front clip of the 4wd frame.
but.. how realistic is this idea?
79 Chevy 3/4 Longbed = just parts now
http://67-72chevytrucks.com/vboard/s...d.php?t=572221
Wanting to Start: HELP!
79 Crew Cab, 1st got to get the basics.
http://67-72chevytrucks.com/vboard/s...99#post6192399
msblackbetty79 is offline   Reply With Quote
Old 09-07-2013, 10:47 PM   #2
msblackbetty79
Re: frame swapping?
or would it just be more simple to buy another 70s-80s k5 and ditch the body just buy it for the 4x4 frame?
if the frames are the same it'd be cheaper for me.
because i already own it!
Old 09-08-2013, 08:51 AM   #3
bdiamond
Re: frame swapping?
You could swap the leaf spring hangers over, I'd think, and reuse the 2wd frame. They swap 4wd's into 2wd's all the time. I don't see why it wouldn't go the other way too
bdiamond is offline   Reply With Quote
Old 09-08-2013, 11:29 AM   #4
K6.0
Re: frame swapping?
You don't see this everyday. Mine is 4wdit i want a 2wdcar its a shame you are so far away we could swap frames
K6.0 is offline   Reply With Quote
Old 09-08-2013, 11:41 AM   #5
msblackbetty79
Re: frame swapping?
your right, it shouldnt be that hard, im sure that frame already has pre drill holes too
Old 09-08-2013, 07:59 PM   #6
BaggedRanger
BaggedRanger's Avatar
Re: frame swapping?
There are differences between the 4wd and a 2wd frame.. It is easier to go from a 4 wd to a 2wd than the other way around if you are specifically asking about frames.
My suggestion would be to get the 2wd and sell it and buy a 4wd. There are more 4wd then there are 2wd trucks out there. You can get the premium price for the 2wd that you wouldn't get for the 4wd.
If you want to know what is different..
1. there are holes in the frame for the spring perches int eh front.
2. the e-brake cable runs into the frame further down than the 2wd.
3. the rear spring hangers are longer than the 2wd ones.
Those are the ones off the top of my head.. This I know because my 2wd frame is messed up and I bought a 74 4wd frame to replace it with.
BaggedRanger is offline   Reply With Quote
Old 09-12-2013, 08:59 PM   #7
texastruckjunky
texastruckjunky's Avatar
Re: frame swapping?
I went the other way from 4WD to 2WD. this is before, during, and after.
Life is to short to drive anything else
texastruckjunky is offline   Reply With Quote
