Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 09-08-2013, 12:35 AM   #1
Captainfab
60-66 Nut
Auxiliary Heater
This is an auxiliary heater out of a '85 G sereis van RPO code C36. This would be the perfect addition to your Suburban or Panel. I verified that the fan works, and the core does not leak. One of the mountiong bosses on the bottom broke off when I was unbolting it. I glued it back on with some Gorilla glue, which I have had good luck with. It does seem to be good and solid. Unfortunately part of the surround is missing, but it shouldn't be too difficult to make one that fits the look of your rig. I'm asking $60.00 plus shipping.
Old 09-10-2013, 11:57 PM   #2
Captainfab
60-66 Nut
Re: Auxiliary Heater
Bump......
Old 11-27-2013, 02:29 AM   #3
Captainfab
60-66 Nut
Ttt
Old 12-10-2013, 08:33 PM   #4
aggie91
I'm just glad to be here!
aggie91's Avatar
Captain
Do you still have it? What would the best your could do shipped to Longview, TX 75605?
I might have to get a set of your power steering brackets too...
Thanks,
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 12-10-2013, 08:35 PM   #5
aggie91
aggie91's Avatar
sent you a PM too.
Karl
The LST Challenge:
Old 12-11-2013, 01:16 AM   #6
Captainfab
60-66 Nut
Yes I still have this heater. I'm sending a reply to your PM.
Originally Posted by aggie91 View Post
Captain
Thanks,
sent you a PM too.
Old 04-16-2014, 12:11 AM   #7
Captainfab
60-66 Nut
Ttt
Old 11-01-2014, 12:45 AM   #8
Captainfab
60-66 Nut
It's starting to get cold again..........
Old 11-01-2014, 11:45 AM   #9
pimpston65
pimpston65's Avatar
where would i mount it? in the back and would i need to split the heater hoses to add this piece?
pimpston65 is offline   Reply With Quote
Old 11-01-2014, 11:03 PM   #10
Captainfab
60-66 Nut
It is designed to mount in the rear passenger area of a Suburban, Panel or Van. Yes you will have to install a Tee or Y in your heater hoses to route coolant to this auxiliary heater. You will also need to run a wire to control the fan. When the temperature gets much below 20-25 degrees the Suburbans, Panels and Vans become hard to keep warm, particularly for the passengers in the rear.
Old 11-02-2014, 07:59 AM   #11
pimpston65
pimpston65's Avatar
i'll take it...going to 48180
Old 11-02-2014, 04:23 PM   #12
pimpston65
pimpston65's Avatar
im pass on the unit, i found one on a pic...
