![]() Join Date: Sep 2012
sidemarker ?
Ok, so My 69 Cst has sidemarker lights and to my knowledge the body panels on the truck are all original. Now for the life of me I dont understand but there is no electrical wiring for any of the sidemarker lights front or back. I dont want to get into a debate on whether or not its the right panels but my question is this.I plan on rewiring this truck from front to back but I want to get this truck inspected and titled in my name before I go that far and need to know,(1)is it ok to splice into the front grill blinker/running light and run a pigtail to the sidemarkers, and (2) is it ok to do the same for the back and run it so that they dont brighten when I hit the brakes. I realize this is sort of rigging it but I just need to get it passed inspection and to get it till I can afford the whole harness for the truck. Thanks for any input you guys can give me!!
2WD Jimmy
![]() Join Date: Mar 2005
Re: sidemarker ?
You wont need side marker lights for the inspection if your truck just had side marker reflectors to begin with.
Re: sidemarker ?
In Texas, side markers are not part of the safety inspection.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
Re: sidemarker ?
Hmm, ok. I called the inspection place and they said if it has lenses in the side that required bulbs that they would have to have bulbs in them but I didnt think that was right. Heck now I dont know what to do. Thanks for the info guys.
Re: sidemarker ?
From TXDPS webpage:
Items of Inspection for a Pickup, Panel, or Truck Under 80" 05.02 Inspect Every Pickup, Panel, or Truck Under 80 Inches Wide For: (Listed in suggested order of inspection) * Check for evidence of Financial Responsibility 1. Horn 2. Windshield Wipers 3. Mirror 4. Steering 5. Seat Belts 6. Brakes (system) Parking - (beginning with 1960 models) 7. Tires 8. Wheel Assembly 9. Safety Guards or Flaps (if four tires or more on rearmost axle) 10. Exhaust System 11. Exhaust Emission System (beginning with 1968 models) 12. Beam Indicator (beginning with 1948 models) 13. Tail Lamps (2); (1) if 1959 model or earlier 14. Stop Lamps (2); (1) if 1959 model or earlier 15. License Plate Lamp (1) 16. Rear Red Reflectors (2) 17. Turn Signal Lamps (beginning with 1960 models) (mea-sure if 1959 model or earlier) 18. Head Lamps (2) 19. Motor, Serial, or Vehicle Identification Number 20. 1988 & newer - inspect for window tinting or coating 21. Gas caps on vehicles 2-24 model years old. Side markers are required on: 20.24 Side Marker Lamps. Refer to Reference Section for lighting diagrams. 1. Required on all: Buses 80 inches or more in overall width. Trucks 80 inches or more in overall width. Trailers and semitrailers 80 inches or more in overall width. Trailers and semitrailers 30 feet or more in overall length. Pole trailers.
![]() Join Date: Feb 2011
Re: sidemarker ?
Does yours have bulb sockets ? Win they first started putting side markers on the trucks they were just reflectors, at some point they started to put bulbs in. On your question on the wiring. Yes, just make sure on the backs you splice into the wire for the tail light not the brake.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. |
#7 | |
Re: sidemarker ?
#8 | |
Re: sidemarker ?
#9 | |
Re: sidemarker ?
How long have you had your truck, and do you know anything about its history before you got involved?
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. ![]() |
Re: sidemarker ?
Well only what they told me but who knows how accurate it is and it is a 45 YO truck so the reflectors could have been switched out with lenses with bulb places on them as well. I like the side markers lit up so I think I am going to wire them up with lights anyway
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
Re: sidemarker ?
I had a 1969 CST and it was an early build, October 1968. It also had reflectors and no bulbs. I asked the same question as you and found out from here that the side reflectors only started to be standard equipment later in the 1969 build year.
Side markers on vehicles all were mandated by the Feds for the 1968 model year and I guess it took a while for GM and the other manufacturers to install lights in the reflectors.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#12 | |
Re: sidemarker ?
#13 |
Re: sidemarker ?
#14 |
2WD Jimmy
Re: sidemarker ?
I had an original 69. It had side reflectors with spots for bulbs but No Bulbs. You are OK, don't sweat it.... Honest.
Posted via Mobile Device |
#15 |
Re: sidemarker ?
Cool, thanks everyone for all the replies and info very much!!!
#16 | |
Re: sidemarker ?
#17 |
Re: sidemarker ?
Just wanted to thank everyone for theyre information and input, I Got the sidemarkers all wired up and working correctly with no issue at all. I know I didnt need to but I like the lights on the side so I decided to wire them up. Thanks everyone again for all there help!!
#18 | |
![]() Join Date: Mar 2000
Re: sidemarker ?
Paul @ GMCPauls |
#19 |
![]() Join Date: Dec 2012
Re: sidemarker ?
That is very interesting Paul, never knew that
1971 GMC Sierra 1959 GMC 100 |
#20 | |
Re: sidemarker ?
