Any one using a hidden radio antenna that works
I'm looking for a antenna for my stereo and from what i've read a lot don't work well,?is there any one that has one that does?
Re: Any one using a hidden radio antenna that works
Sort of hidden. Extends when the radio is switched on.
Retracts when key or radio is turned off. ![]()
Jimi J from I-Oh-Way '57 Panel 3105 Met this deer... Roof Swap on my Panel Jim's Bread Truck |
i used the cheapest antenna from autozone and wire tied it under my pass step, works great.
i slid some plastic tube over it so as not to ground the antenna to the metal.
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
I have used a bunch of those. The best one I found was the one with the fiberglass wings on it. I found that routing the wire that connects it across the dash length wises (because it affects signal as well) and keep em from the battery cables due to static and they work fine. You cant bury them under a bunch of crap and they like to be mounted closest to the top of the dash as possible.
My '59 Build Thread |
#6 | |
![]() Join Date: Mar 2007
Marc Posted via Mobile Device
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
''wire tied under the pass step''
i tried under the dash and did not get much reception under the step is out of view and outside of the truck as youngrodder confirms, it works well
