Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 09-08-2013, 04:44 PM   #1
SweetandLong68
Your UncleBen
SweetandLong68's Avatar
Suspension setup front/rear for big hp truck?
Well my truck build has taken a turn for the dark side! LOL
I was gonna just make my truck a neat little driver but now that I have sold my street strip car and I have this blower motor that wants to find its way into my truck!
So I am planning this build and would love to hear some input on suspension setup. I am assuming coilovers front/rear? Give me the rundown on what I need or what is working.
This motor will be right at 1000hp on the race fuel tune, Powerglide trans, Fab 9 rear. Not sure of the gear yet. What you guys thinking?
CHRIS
68 C10 shortbed -- Street/Strip
SweetandLong68 is offline   Reply With Quote
Old 09-09-2013, 10:28 AM   #2
Marv D
Registered Truck Offender
Marv D's Avatar
Re: Suspension setup front/rear for big hp truck?
I'm only running about 1/2 that HP but there comes a point where you are going to have to look at what your doing. racing or street / strip / show / toy. With that kind of HP you need something more rigid than the stock frame, or at a MINIMUM a full cage structure to build some rigidity into the stock frame. Then comes the need for a back-half to fir the big tires under it, and the need for a front half to fit a mor suitable drag suspension under it,, what's left a 4 or 5 foot piece of the stock frame... Like I said, comes a time to decide what your building and do it ONCE, right!.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 09-11-2013, 09:26 PM   #3
SweetandLong68
Your UncleBen
I am really leaning towards the older school version of the 67 Drag Truck that is famous on the boards... It will be a radical street/strip setup where everything is built for the track but can be on the street if the need/want arises... I am building the motor to run on pump gas but can up it if needed for the track. 496 BBC with roots blower is the combo...
lata
CHRIS
Old 09-11-2013, 09:29 PM   #4
SweetandLong68
Your UncleBen
I already have alot of parts that I have been collecting to put this drivetrain in my old G-body... But it is gone now... I was planning a 29.5x10.5" tire. I know these trucks can take more tire so may go to a W.
Old 09-12-2013, 01:09 AM   #5
66 C10 383
Sounds about like what I'd done. Collected parts for a g-body build and then sold it. Now I'm adapting what I have/can to my truck. ... minus the 1000hp big block ...
Good luck and choose wisely, that's a bunch of horsies to be contained ...
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 09-12-2013, 10:54 AM   #6
70shortwide
you dont need to cut the rear frame for bigger tires unless you just have to have a 33x15 tire on the thing. my buddys 67 is running low 5's in the 1/8 with the stock frame rails on a 315 radial.
70shortwide is offline   Reply With Quote
Old 09-03-2014, 02:51 AM   #7
moggey01
Mine is kind of what your talking about . The truck is not finished but I plan on driving mine on the street some. I am using the stock framerails with alot of changes made. It will be a while before I am running but it takes alot of work and time to get the results you want.
moggey01 is offline   Reply With Quote
