Old 09-08-2013, 06:03 PM   #1
Fastest32
Fastest32's Avatar
sssoooo, I guess I went too low.
So I finally got around to doing my front disc brake conversion along with some drop spindles. I got the spindles off of craigslist and the guy said they were "2 drop spindles but they looked like more to me. Anyway I put it all together and the tires only have like a "1/2 of clearance. I tried to take it around the block and it was hitting getting out of the driveway. I have the stock springs that came from the 78 donor. I'm thinking of putting those in and maybe taking a coil or half a coil off. Right now it has the stock springs with one and a half coils cut plus whatever the drop spindles are. I think it may have dropped the truck "3 so I guess they're "3 drop spindles. My other option is putting the stock 78 spindles on. What do y'all think I should do?
BaBaBooey BaBaBooey
GO SPURS GO!!!
Fastest32 is offline   Reply With Quote
Old 09-08-2013, 06:04 PM   #2
Fastest32
Fastest32's Avatar
Re: sssoooo, I guess I went too low.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 09-08-2013, 06:06 PM   #3
Fastest32
Fastest32's Avatar
I wish I could leave it this low and lower the back a little more. I love how low it sits just wish it would rub.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 09-08-2013, 06:34 PM   #4
71swb4x4
71swb4x4's Avatar
What's it rubbing on, the inner fenders? If so, pull them off.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-08-2013, 06:39 PM   #5
cochino12
It followed me home?
cochino12's Avatar
looks bad ass, I'd make some new inners
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 09-08-2013, 06:41 PM   #6
Fastest32
Fastest32's Avatar
Yeah it hits the inner fenders but it hits right where they bolt to the outer fenders so it looks like if I take the inners out it'll still hit the outer? Also what would I do about the hood hinges?
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 09-08-2013, 07:28 PM   #7
joedoh
joedoh's Avatar
too low? what is that exactly?
I tubbed my inners and cut the fender out to the hood. You can try pulling the inners and giving the uppers a couple camber shims, camber scares some guys but I promise it wont wear uneven unless the toe is off
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 09-08-2013, 07:56 PM   #8
LT1 Burb
LT1 Burb's Avatar
That's strange, I have 3" drop spindles with bags and even with it as low as yours mine has never rubbed. Must be the tire height difference.
LT1 Burb is offline   Reply With Quote
Old 09-08-2013, 08:14 PM   #9
Fastest32
Fastest32's Avatar
Probably. They're 235/70r15's
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 09-08-2013, 08:17 PM   #10
MisterC
MisterC's Avatar
What brand of tire is that? I love them!
Poor and content is Rich...and Rich enough! - William Shakespeare
1966 C10 Custom Cab "Luigi"
Big Window - SWB Fleetside
350 V-8 - Powerglide
My not so much a build thread as a "Slow Progression Thread":http://67-72chevytrucks.com/vboard/s...d.php?t=486894
MisterC is offline   Reply With Quote
Old 09-08-2013, 08:33 PM   #11
ol_skool_chevy
ol_skool_chevy's Avatar
Change to a 3/4 ton spring less travel
Measure with a yard stick
Mark with Chalk
Cut with a torch
Built it yourself, don't count on others to to do it for you or with you. It will never get done
ol_skool_chevy is offline   Reply With Quote
Old 09-08-2013, 08:40 PM   #12
Fastest32
Fastest32's Avatar
Homemade whitewalls.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 09-08-2013, 09:40 PM   #13
T Smith
T Smith's Avatar
Part of the rubbing problem is most drop spindles space your wheels out 3/4" on each side. I'd leave them in there and try the stock 78 springs and trim accordingly to get the drop you want with no rubbing.
T Smith is offline   Reply With Quote
Old 09-08-2013, 10:36 PM   #14
Fastest32
Fastest32's Avatar
Thanks. That's gonna be the plan for now.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 09-09-2013, 12:43 AM   #15
Hparker619
I think it look's good ! it look's as low as mine
Hparker619 is offline   Reply With Quote
Old 09-09-2013, 07:44 AM   #16
Fastest32
Fastest32's Avatar
I agree but there's no way I can drive it like that. Does yours not rub? What size tires are you running? I don't want to cut up my fenders really.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 09-09-2013, 08:12 AM   #17
T Smith
T Smith's Avatar
I'm running the same size tires, 235/70-15 but on 8" rims. This is about as low as I can drop mine without tire rub on sharp turns, like parking, but it doesn't rub in normal driving at all.
Old 09-09-2013, 10:39 AM   #18
KJSR
KJSR's Avatar
I think you should clearance what it is hitting and lower the back to match. Maybe a bit smaller tire on the front??
1936 Chevrolet 1/2t
1964 Chevrolet C10
1964 Chevrolet C10 (sons)
1965 Chevrolet K10 Suburban
1969 Chevrolet C10
1937 Plymouth P4
KJSR is offline   Reply With Quote
Old 09-10-2013, 04:37 PM   #19
ChevyFreak60
ChevyFreak60's Avatar
Put a smaller tire for sure.....
1960 Chevy Stepside 2wd
1966 Chevy Fleetside 2wd
1965 Chevy Suburban 2wd
1965 Chevy Fleetside 4X4
1960 Chevy Fleetside BBW 2wd
ChevyFreak60 is offline   Reply With Quote
Old 09-10-2013, 07:58 PM   #20
Blue666
Those nearly 50 year old springs are probably sagging a bit. An original eq. replacement should run around $100.00. I would not waste any time with 1970's springs as they are just as worn.
If you used a 3" drop spindle, you will still get a three inch drop. New springs will restore the ride & handling.
Blue666 is offline   Reply With Quote
Old 09-10-2013, 08:01 PM   #21
Blue666
I had the same problem when I did my drop spindles. My original eq. springs only had 80K.
Old 09-10-2013, 08:06 PM   #22
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Thomas, are those wheels Astro Supremes ?
Old 09-10-2013, 08:10 PM   #23
T Smith
T Smith's Avatar
They are Summit Legend 5's, I don't remember them costing this much though, seems like I caught them on sale...
http://www.summitracing.com/parts/su...73c0/overview/
Old 09-10-2013, 08:12 PM   #24
Tx Firefighter
Thank you for the quick response Thomas.
Back to the normal programming....[/hijack]
Old 09-10-2013, 08:31 PM   #25
Fastest32
Fastest32's Avatar
I might order some two inch drop springs. Probably gonna put the 78 springs in it to get back on the road.
BaBaBooey BaBaBooey
GO SPURS GO!!!
