Old 07-07-2003, 12:46 PM   #1
crew70
crew70's Avatar
got good Idea for getting under coating off??
do any of you have a good easy way to get under coating of?
70 chevy 3/4 ton 4x4 402ci crewcab
3/4ton
94 gmc 1 ton dually crewcab 454ci
99 suburban 5.7
2001 500cc ski-doo mxz
95 500cc ski doo fan
650 bombardiar 4 wheeler
crew70 is offline   Reply With Quote
Old 07-07-2003, 12:50 PM   #2
Randy70C-10
Randy70C-10's Avatar
I've heard that you can heat it with a torch, be careful not to warp your truck though.
Randy70C-10 is offline   Reply With Quote
Old 07-07-2003, 01:20 PM   #3
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
gas, it works as does most petro based liquids
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 07-07-2003, 01:47 PM   #4
Linus0014
Guest
Posts: n/a
I just got done doing under my bed. I used a good old razor to get most of it off. Then I used heavy duty strength oven cleaner. Let it sit for about 10 minutes, then scrub it with a wire brush. Then I used a pressure washer to finish. It took it down to bare metal. I couldn't have been happier!
Old 07-08-2003, 07:58 AM   #5
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Give a thin scraper a try. (preferably a well seasoned one with rounded corners, not a new one) You might be surprised as most times, this stuff scrapes right off.
If you heat it up, it may be more difficult to remove.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 07-08-2003, 09:24 AM   #6
cdowns
cdowns's Avatar
www.eastwoodcompany.com they have a product called underoff for removing undercoating, also my local auto-paint supply store has a similar product(cheaper) which i've used with good results
