Old 09-08-2013, 09:49 PM   #1
groundbound64
shock advice
Hey Guys n Gals,
I just installed my air ride setup. Front - 2 1/2 drop spindles, 2600lbs bags.. Rear - 2600lbs bags, viair comressors, Accuair control.
I wanted some advice on what shocks I should use ? thanks in advance
64 C10 Stepside 350/4psd Driver/Project on air.
Dom bags, Dual Viair and AccuAir
08 Ford F150 Limited- F-word ! Daily Driver
.......................____
..........._______l/ \____
...........|_/(0)\_ll____/(0)_l.
groundbound64 is offline   Reply With Quote
Old 09-08-2013, 10:38 PM   #2
Fastest32
Fastest32's Avatar
Re: shock advice
Who cares? Post some pics! Lol. Sorry no advice on the shocks but I wanna see some pics!
BaBaBooey BaBaBooey
GO SPURS GO!!!
Fastest32 is offline   Reply With Quote
Old 09-08-2013, 11:18 PM   #3
chakah
chakah's Avatar
Re: shock advice
"El Jerry"
'03 3500 Duramax dually
'96 1500 ext. cab Chevy
'66 swb C-10
'63 Panel
'60 VW vert
'56 VW vert
chakah is offline   Reply With Quote
Old 09-09-2013, 01:36 AM   #4
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: shock advice
I ran no shocks on a bagged setup before, trust me thats not the way to go.
Nitro drop shocks are the "Generic" answer for most lowered vehicles, since they make a million sizes and they aren't that expensive. You don't really need to spend big money on an adjustable shock, since the bag effectively changes the dampening and "rate" in itself.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-09-2013, 01:56 AM   #5
joedoh
joedoh's Avatar
Re: shock advice
I second Br3w City comments with the following caveats:
measure the travel of your suspension, and try and put the shock in so it has just a bit more travel when fully aired out, I know lots of guys who laid the truck out on a cruise and bent a shock or broke a mount because they hit a bump. A good auto parts store will let you measure a bunch of shocks.
get a gas charged shock, airbags have more oscillation than a metal spring and a standard shock will be foamed and useless in a very short time. Monroe makes a great rear shock, monroe MON31000 shocks for $30 a pair. They are 12" compressed and 19.5" extended, about 8" of travel, part number is 94008. They would work up front too if that meets your length between shock mounts when laid out.
http://www.amazon.com/Monroe-31000-Monro-Matic-Sho... http://www.amazon.com/Monroe-31000-Monro-Matic-Sho...
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
Last edited by joedoh; 09-09-2013 at 02:02 AM. Reason: shock price went up slightly
joedoh is offline   Reply With Quote
Old 09-09-2013, 05:01 PM   #6
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: shock advice
it will kinda limit your selection on the front of these trucks.
I'm static about 5" and I have to run around a 10" shock, it gets hard to find anything smaller than that. It still extends to 13+ which works fine, but anytime you get less than about 9.5" shock length bottomed out, you get put into the expensive brands pretty much no matter what.
Old 09-09-2013, 10:55 PM   #7
groundbound64
Re: shock advice
Thank you for the advice ! and I will post pics once I get the box back on and finish the minor tweaks.
