1971 chevy longhorn
hey does anyone know where i can buy a carrier bearing for a 1971 Chevy longhorn. my truck uses a weird two piece drive shaft, the front half comes straight out of the transmission goes into a carrier bearing about where the back of the cab ends, then after the carrier bearing the second half of the drive shaft angles down and goes to the rear end. lmc doesn't have anything listed and this is kind of a bastard truck because of the longhorn, so I'm not sure what is interchangeable and whats not. can i use the carrier off a regular 3/4 ton
Re: 1971 chevy longhorn
The 2 piece driveshaft is factory, all longbeds and longhorns came like that. The carrier bearing should be the same as a standard longbed 3/4 ton, and most parts stores should be able to order you one.
Zach 1970 Chevrolet Custom Camper K20 1971 GMC Super K2500, 12V/NV4500 swap in progress 1971 Chevrolet Custom C10 1972 Chevrolet Custom Deluxe C20, 5.3/4L60E 1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi 2004 GMC Sierra 2500HD, LB7/Allison, CCSB 2005 GMC Sierra 1500, 5.3/4L60E, CCSB |
