Old 09-09-2013, 03:05 AM   #1
BigHappy661
rookie
hi I'm new on here I have a 1965 c10 long bed big window second owner the most I've done is buy a fleet side bed and am about to put in a 350 with a 350 trans I have a 230 with a 3 speed but was wondering if the 3 speed cross member is the same as a 350 cross member
BigHappy661 is offline   Reply With Quote
Old 09-09-2013, 03:41 AM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: rookie
Hey man ... Welcome aboard !!
The 3speed crossmember supports the bellhousing, essentially the rear of the engine, while the 3-speed just hangs from it.
Typically, that rear crossmember is removed when converting to an auto.
An auto crossmember will have to be acquired, or one fabbed up.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 09-09-2013, 11:56 PM   #3
Captainfab
60-66 Nut
Re: rookie
Welcome to the forum
Yes the bellhosing crossmember will need to be removed. Then you will need a crossmember for the rear of the TH350. For that you can use either a factory trans crossmember for a '63-'87 pickup, Suburban or 2wd K5 Blazer, or one of the aftermarket crossmembers. Either way you will have to drill the mounting holes.
Old 09-10-2013, 12:21 AM   #4
BigHappy661
Re: rookie
how would I go fabricate it Can I get a diagram or some specs sizes I'm learning as I go
