Old 09-09-2013, 12:06 PM   #1
Jmiller022
Jmiller022's Avatar
what gears???
My truck is for running around town, and enjoying with my family. It won't see a drag strip. So Im looking for the highest gears that I can run to improve mileage as best as possible.
Im running 3.73s now on a 28" tire. I average about 18mpg. I will be swapping in a LSD soon and would like to look at some 3.23s or possibly even 3.08s.
its a regular carb short bed with a 5.3/4l60e. I believe it weighs around 3300lbs(could be wrong).
What are you running in your "driver"?
68' c10 stepper 5.3/4L60e
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917
Jmiller022 is offline   Reply With Quote
Old 09-09-2013, 02:09 PM   #2
Indian113
Indian113's Avatar
Re: what gears???
I have 3:42's and a 700R4 behind my 5.3 in my S10 and get around 20 mpg's on the HY. I still have plenty of pickup and go, I don't think I would go much lower with a OD trans as it might bog due to low RPM's.
Indian113 is offline   Reply With Quote
Old 09-09-2013, 02:18 PM   #3
Hart_Rod
Hart_Rod's Avatar
Re: what gears???
+1. Low rpms can be as bad as high rpms on mpg.
Hart_Rod is offline   Reply With Quote
Old 09-09-2013, 08:04 PM   #4
oldman3
oldman3's Avatar
Re: what gears???
jmiller022, I agree with indian113 and hart rod. 3:73 with OD {approx 70%) would be 2:61 and 3:42 with OD would be 2:39. Anything lower than that and I think your tranny will be shifting back and forth and mileage may suffer, just my 4 cents worth (inflation)...Jim
oldman3 is offline   Reply With Quote
Old 09-09-2013, 11:12 PM   #5
Blackpony
Blackpony's Avatar
Re: what gears???
I am running 3.73 with my 5.7 4l60 combo and i average around 19-20 hwy. 3.42 might net a tick better but i doubt it. at 70 mph im around 2200 rpms
Blackpony is offline   Reply With Quote
Old 09-09-2013, 11:43 PM   #6
Ryan Hubbard
Re: what gears???
I don't have an LS engine but I am running a blown 350 with a 4l80e and am running a 3.55 rear gear with 29" tires and I find it a great combo. I am averaging 16 mpg doing 75-80 mph or sitting in traffic in So Cal.
Ryan Hubbard is offline   Reply With Quote
Old 09-10-2013, 12:46 AM   #7
solidaxel
solidaxel's Avatar
Re: what gears???
Have you considered a taller tire on the rear?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-10-2013, 07:51 AM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: what gears???
I have a 4.8/4l60e/28" and now I have 3.73's getting about 19.5 on the hwy. before I rebuilt the rear, I had 3.8's and the same combo and got 18.5mpg hwy.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-10-2013, 08:17 AM   #9
homemade87
Re: what gears???
I have a 82 with a 04 5.3 and 4l60. Factory set up with a tune. I am running the 3.23 gear and does great. It has 28" tires. I get no shifting problems. Around town it does great and on the road I did a 350 mile trip ( interstate) and got 22.3 mpg. I could not be happier with the 3.23. If you plan on towing you may concider a higher number gear.
homemade87 is offline   Reply With Quote
Old 09-15-2013, 10:09 PM   #10
cjohnson6772
cjohnson6772's Avatar
Re: what gears???
I am running a cammed 6.0L/4L80e with 28" tire in a 72 swb with 3.07 gears. I can run at 60-65 mph and it never shifts out of OD. You can definitely hear the torque convertor locking and unlocking which is annoying. When the TC is locked, the RPMs are so low and the drone can be pretty obnoxious even with subdued mufflers.
Considering 3.73s with posi if I can find a factory unit. Would love 3.42s with posi, but I don't wanna spend $800 on my rearend at the moment.
I should also say that interstate cruising (80 mph give or take 10 mph) is great
cjohnson6772 is offline   Reply With Quote
