Old 09-09-2013, 04:26 PM   #1
solidaxel
solidaxel's Avatar
78 rear axle ratio ??
I am trying to prove the rear axle ratio on my 78 1/2ton Silverado with out taking off the rear cover
the numbers on the pass/ side tube are KAS 229 W 8S
This is a stock 350 Auto that i have had since 78 and the numbers are not in the glove box that says anything about the rear axle ratio.
Ehere can I find this info, as I need it for the programmer on the LS computer!
Thanks Folks
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-09-2013, 04:57 PM   #2
tlawre87
tlawre87's Avatar
Re: 78 rear axle ratio ??
Count the number of times the drive shaft spins to the rear wheel (jacked up of course)
Trevor
74 C20...work in progress.
04 Saturn Ion...Daily Driver
tlawre87 is offline   Reply With Quote
Old 09-09-2013, 05:09 PM   #3
Keith Seymore
Keith Seymore's Avatar
Per the info packet in the GM Heritage Center archives (page 15 of the pdf; page 12 of the original):
http://www.gmheritagecenter.com/docs...olet-Truck.pdf
base axle is a 3.07. That assumes no one has changed it.
If you had an optional axle ratio it would appear on the SPID label.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 09-09-2013, 05:23 PM   #4
solidaxel
solidaxel's Avatar
It is not posi-trac!
LS 3 4L70E
Old 09-09-2013, 05:29 PM   #5
solidaxel
solidaxel's Avatar
Thanks, after many tests rotations, I think the 3:07 is accurate.
THANKS
LS 3 4L70E
Old 09-09-2013, 05:35 PM   #6
solidaxel
solidaxel's Avatar
After reading the Heartiage center doc. it said that a Heay Half, which is what this is, it says that it is a 3:40 !
LS 3 4L70E
Old 09-09-2013, 05:42 PM   #7
solidaxel
solidaxel's Avatar
The computer is programed fpt the 3:40 - 1, I guess i will live with this decision !!!
Thanks for the info
LS 3 4L70E
