Old 09-09-2013, 08:25 PM   #1
dgardhawk
1969 gmc 4x4 1500 deluxe
i have a 350 eng. 350 trans. and get terrible fuel mileage. is there anything that i can do to get better mpg without changing engine and trans.
thanks,
dgardhawk is offline   Reply With Quote
Old 09-09-2013, 08:34 PM   #2
jocko
jocko's Avatar
Re: 1969 gmc 4x4 1500 deluxe
options:
a. lower numerical (i.e. higher) diff gears, front and back ($$$)
b. that's about it considering your restraints....
If you're really concerned, the o/d trans is about the only other option - and it requires moving the eng fwd about 2", a kit to mate the o/d trans to the t-case, etc etc.
I don't have any other ideas than that.
Remember to include the tire diameter in your gearing calculations, big deal on a 4x4 - and may be part of your current problem, depending on your current tire size/gearing, a tire change might be all that is required.
If you know your differential gear ratios and tire diameter, we can give you an idea what rpm you're running (and how it affects gas mileage).
WELCOME to the board!
Old 09-09-2013, 09:05 PM   #3
dgardhawk
not sure of diff. gear ratio but i am running around 3500 rpm at 55 mph and i can watch the gas gauge go down.
Old 09-09-2013, 09:15 PM   #4
2bbl or 4bbl? You can do best with a 4bbl. When are you running 3500 rpm? Kinda vague info so far
Old 09-09-2013, 09:23 PM   #5
67_C-30
I have a radical idea!
67_C-30's Avatar
The tune of the engine and condition of the carb has a lot to do with it also.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 09-09-2013, 09:25 PM   #6
dgardhawk
it is a 4bbl. 3500 is highway speed 55 mph or higher
Old 09-09-2013, 09:34 PM   #7
blue 72 gmc 4x4
blue 72 gmc 4x4's Avatar
Sure does! Start there!
1955 GMC Hydramatic
1959 Chevy Spartan 100
1969 Chevy C/10
1969 Chevy C/30 Bruiser
1972 GMC (Wrecked)
1972 GMC pickup..old blue
Restored Vent Windows
https://67-72chevytrucks.com/vboard/...d.php?t=766598
1955 GMC hydramatic build
http://67-72chevytrucks.com/vboard/s...d.php?t=429417
blue 72 gmc 4x4 is offline   Reply With Quote
Old 09-09-2013, 10:34 PM   #8
Shyguy
Junior Member
Shyguy's Avatar
Are you really going 55 or is that what the speedometer reads?
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 09-09-2013, 11:52 PM   #9
jocko
jocko's Avatar
Yes. If you don't know if you have the original gears, check rpm vs speed with a GPS unit. What you are reading on speedo is not relevant. 3500 at 55 doesn't provide enough info to know where to start. Tuning the motor, yes, could provide 1 or 2 mpg improvement, but not much more. Btw, what IS your current fuel mileage, specifically?
Old 09-10-2013, 01:27 AM   #10
396ci
396ci's Avatar
is your truck running in 4wd all the time? you could remove your front drive line when your not off road. might get you a few mpg's.
Brian
XNGH ECV Chapter 58
1972 Jimmy / Blazer Project 2wd
1974 Chevy Crew Cab Shorty
396ci is offline   Reply With Quote
Old 09-10-2013, 02:23 AM   #11
swamp rat
swamp rat's Avatar
Thats high rpm's, I have 4:10's and 33" tires i'm at about 2700 at 60 mph, i have a turbo 350 tranny.
You probably have 4.56 gears on your differentials
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 09-10-2013, 08:21 AM   #12
dgardhawk
i get 5 miles per gallon whether i get on it or not
Old 09-10-2013, 08:22 AM   #13
dgardhawk
no it is not
Old 09-10-2013, 08:33 AM   #14
So.Cal.Super
It'll Buff Out!
So.Cal.Super's Avatar
what size tires are you running?
"Instructions are just another mans opinion"
Become a Supporting Member
Man Card Rules
http://67-72chevytrucks.com/vboard/s...d.php?t=634550
72 Chevy Cheyenne Super 400 LWB
So.Cal.Super is offline   Reply With Quote
Old 09-10-2013, 04:58 PM   #15
MARKDTN
Fuel injection swap. TBI or TPI is easy to add to a stock bottom end. With only a TPI swap in my '83 K20 (same transmission, same rearend) I went from 14.5mpg city to 17+ and 17 hwy to 22.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 09-10-2013, 08:59 PM   #16
BrianG
BrianG's Avatar
Agreed, that's a lot of rpms for 55 mph. I'd check the gear ratio. You might not want to go with too high of a gear depending on what your tire size is, and how you normally drive it (city/highway). you want to get into the right rpm range for your engine and your style of driving. 5 mpg is pretty bad, but a lot of factors can contribute to that. It does sound like your gearing is pretty low though. Could the tranny be slipping at all? Do you notice that it shifts into second and then third right away when you take off? Is it actually going into all three gears. Is it stuck in low lock? Just a few things to think about.
BrianG is offline   Reply With Quote
Old 09-10-2013, 09:50 PM   #17
White70C20
White70C20's Avatar
There's some good info here. Makes me wonder if my truck has 4.56 gears in my rear diff. At 65 MPH my truck is screamin'!
White70C20
1970 Blue C20 - 250, 4 speed
1985 Ford Thunderbird
2005 Pontiac G6
White70C20 is offline   Reply With Quote
Old 09-10-2013, 09:58 PM   #18
White70C20
White70C20's Avatar
I don't want to hijack this thread, as I think others could benefit from this too. My truck shifts into second and then into third right away unless I baby it. I can't ever hear it shift into third unless I putt around like a grandma. Is this normal for a TH350?
White70C20
2005 Pontiac G6
Old 09-10-2013, 11:16 PM   #19
swamp rat
swamp rat's Avatar
Shift points can be adjusted internally, plus there is a modulator at the rear of the TH350 that is adjustable as well, you take the vacuum hose off the modulator and get a small screwdriver in there, i forget which way is which but it makes it shift firmer or softer, may even change shift points a little too?
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 09-10-2013, 11:30 PM   #20
mmiddle
mmiddle's Avatar
HEI, Q-jet, Good tune up. 3500 @55?????You should be able to climb a tree!
put 3.55:1 gears in it. headers & free flow exhaust. It seems a though gearing is a major issue here.
OD tranny, EFI take the lift kit off?
There are many things that can be done, but $$$$$$$$$.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 09-12-2013, 10:55 AM   #21
dgardhawk
i have 33x12.50x15 tires
also how do you tell what kind of gears you are running.
Old 07-08-2014, 03:56 PM   #22
dgardhawk
had a dead battery. changed battery and when i hooked up the positive back up i smoked a wire that goes to the firewall. i know i probably have a short to ground so i changed all of the wires to the battery and put a fuse in line on the wire that got smoked and checked the wires to see if i could see anything that was obvious. hooked up positive and popped the fuse immediately. i dont see anything that is obvious, any thing that anyone can suggest would be appreciated. is there a way to bypass the wire that is smoking to see if that one is the problem. and how do you pull the wire out of the plug on the firewall.
Old 07-09-2014, 03:31 AM   #23
swamp rat
swamp rat's Avatar
First thing that jumps out to me here is that by your statement you hooked up the negative cable first then when you hooked up the positive cable the wire got smoked.
Always, Always hook up the positive cable first, tighten it, then hook up the negative last. If the negative cable sparks when you try and install it then it tells you that there is a short in the system that needs to be tracked down, also when you install the negative cable last if you accidentally touch your wrench to the body it won't spark as your tightening the ground, sparks around the battery are not good..
If you try to hook up the neg cable last, touch it to the battery and it does spark, go to the fuse panel and remove one fuse then go back and try reinstalling the neg cable, if it sparks then go to the fuse panel and replace that fuse and try another. do this until you don't have a spark and you have isolated the circuit
What you don't mention is what wire? what color? where does the wire originate and lead too?
In the Electrical FAQ section there is a full color schematic available you could find this and figure out what wire your talking about.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
Old 07-09-2014, 07:48 AM   #24
dgardhawk
chased wires most of the day, it is the red wire, it looks like it is the hot going to the ignition switch.
Old 07-16-2014, 01:30 PM   #25
dgardhawk
so i pulled every fuse and i still have a short issue. could it be the ignition. it is the red wire going from the battery that melts when i put power to it. so i did a dumb thing and pulled the plug off the back of the ignition under the dash and of course some springs fell out. any idea how to get the ignition off the dash so i can fix it. cant seem to get it out.
