Old 09-09-2013, 09:01 PM   #1
Chvy2NV
Wilwood D52 Calipers ??
I'm putting together a disk brake kit for my 67 but not sure what part # the Wilwood Calipers are. I also found these online for a chevelle and wonder if anyone is using something like this where the parking brake goes inside the rotor.
Truck is automatic. Not sure if Ill need a parking brake.
Here is what my list of parts looks like.
Wilwood D52 Calipers PN??? (Front & Rear)
•Moser 5 lug axles
•Capt Fab Rear Brackets
•Front Rotors : Brake Performance Rotor Dimpled and Slotted. Black Zinc Coated: RB 66022
•Rear Rotors : Brake Performance Rotor Dimpled and Slotted. Black Zinc Coated: 94 Astro AWD: RB 66022
•CPP Spindle: CP30106-4
Chvy2NV is offline   Reply With Quote
Old 09-09-2013, 09:13 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Wilwood D52 Calipers ??
There is 4 total D52 calipers. (not counting color choices)
2 different front.
1.28" wide (6.28 piston area)
1.04" wide (6.28 piston area)
2 different rear.
1.28" wide (2.46 piston area)
1.04" wide (2.46 piston area)
http://www.wilwood.com/calipers/Cali...0Dual%20Piston
Keith
Convert to disc brakes.
Old 09-09-2013, 09:18 PM   #3
lolife99
lolife99's Avatar
Originally Posted by Chvy2NV View Post
•Moser 5 lug axles
I don't think your rotors are the same part number.
Fronts should be 66000.
All are 1.25" width.
Wilwood part numbers will be determined by color choice.
Keith
Old 09-09-2013, 09:25 PM   #4
lolife99
lolife99's Avatar
REAR CALIPERS:
Black Anodize
120-10938
Black Powder Coat
120-10938-BK
Red Powder Coat
120-10938-RD
FRONT CALIPERS:
Black Anodize
120-10936
Black Powder Coat
120-10936-BK
Red Powder Coat
120-10936-RD
Keith
Old 09-09-2013, 11:24 PM   #5
Andy4639
Old member
Andy4639's Avatar
Cool Re: Wilwood D52 Calipers ??
Sorry can't help on the rotor sizes but I say u need a park brake no matter what kind of trans it is. Have u ever seen what the transmission pawl is in a automatic. It's not much! The tip wears out over time also.
Not knowing your exact one this basicly is all that holds your truck from ending up at the bottom of the hill head on into a tree.
I have been a witness to 2 of them failing herd a pop and the truck starts rolling. They were both 350 auto's.
One was a friends car in the drive way, I caught it right before it went over the road.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-10-2013, 04:00 AM   #6
68shortfleet
2 different front.
While on the subject of Wilwood calipers. It has always been my understanding that "upgrading" the performance of a caliper meant that the area of the piston must be increased. Maybe I am just all wrong in hits though process.
The stock truck calipers from 71-87 1/2 and 3/4ton all have a piston diameter of 2 15/16"(2.9375"). This gives a working area of 6.77in^2.
So, with that in mind, how is the Wilwood a performance option when it is a reduction in area?
I will agree that they definitely look better than the stock calipers.
68shortfleet is offline   Reply With Quote
Old 09-10-2013, 08:50 AM   #7
Chvy2NV
Thank you Keith. That was a typo on the front rotor. Correct PN is 66000.
So then these are my PN for the black D 52 calipers.
Front: 120-10936-BK
Rear: 120-10938-BK
Pardon the dumb newbie questions. This internal parking brake shown above has an integrated bracket. (Not being able to use Capt Fabs brackets) ????
Thank you guys for all your help and knowledge.
And oh yea. I'm in S. Fla. we don't have any hills here.
Old 09-11-2013, 01:08 PM   #8
Chvy2NV
Ttt
Old 09-11-2013, 01:57 PM   #9
lolife99
lolife99's Avatar
Front: 120-10936-BK
Rear: 120-10938-BK
Correct on the d52 caliper numbers for 1.25" wide front and rear rotors.
The internal parking brake Wilwood kit (like you posted) has a different smaller caliper,... and will come with it's own caliper bracket.
(I guess you could always sell the CaptainFab brackets, if you decide to go that route)
Keith
Old 09-11-2013, 07:09 PM   #10
Chvy2NV
When you say wide front is it because the rotors see thicker? I was planning on ordering the caption fab brackets this week.
Do you know the PN for the wilwood kit with the ebrake like the one above?
Or what other options are there for ebrake ?
I'm trying to keep it as low budget as possible by putting together a kit.
Old 09-11-2013, 07:13 PM   #11
lolife99
lolife99's Avatar
What rearend are you using?
There is a 11" and 12" rear disc brake kit (with internal parking brake) from Wilwood for a stock '72 rearend.
Go to wilwood.com to find out what is needed.
They make more kits and bigger brakes.
Wilwoods site is really easy to navigate.
Keith
Old 09-11-2013, 07:19 PM   #12
lolife99
lolife99's Avatar
There are 2 different rotor width/thickness' for C10 front disc brakes for the 71-87 trucks.
1" wide rotors or 1.25" rotors.
Your CPP Spindle: CP30106-4 require the wider 1.25" rotors.
The front calipers I listed fit these rotors.
The rear calipers I listed fit the Astro Van AWD rotors you listed, as long as you use the Captain Fab brackets.
Keith
Old 09-12-2013, 06:41 AM   #13
darkhorse970
darkhorse970's Avatar
Good info in here. I have considered the rear disc/Wilwood calipers upgrade. Thanks for the part numbers.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 09-12-2013, 09:01 AM   #14
Chvy2NV
My rear end is a 12 bolt. As far as getting bigger brakes. I'm looking for something that I can possibly run smaller wheels in the meantime (during the build process) Or at least not have to only run much larger sizes.
Link didn't work for me.
Good thing is. I Havnt ordered any of the parts yet.
Thanks for your help again.
Old 09-12-2013, 01:30 PM   #15
sprint_9
sprint_9's Avatar
Wilwood makes a Dynalight kit with the parking brake built in. Like the one you posted for the chevelle. The caliper and rotor won't match front to back if you use the brake performance rotors and d52 calipers on the front, they will be close but not exact.
sprint_9 is offline   Reply With Quote
