Old 09-10-2013, 12:41 AM   #1
solidaxel
solidaxel's Avatar
Brake Booster..... ?
Where do you tap vacuum from a 5.3 to a stock 78 pick up brake booster?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 09-10-2013, 07:48 AM   #2
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Brake Booster..... ?
what year motor? I believe there should be a port on the back of the intake. thats where mine is...
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-10-2013, 09:42 AM   #3
solidaxel
solidaxel's Avatar
The 5,3 is a 2004.
There is a port that goes into the valve cover (maybe T the PCV?)
LS 3 4L70E
Old 09-10-2013, 02:28 PM   #4
Robznob11
Robznob11's Avatar
At the back of the intake there is a round port . If you look at the back above where your oil press sender you should see it. Gm sells a barb that fits in there. Ill have to wait till i get home to get the pt # but i got mine at scoggin dicky in lubbock for about 8 or 10 bucks.
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 09-10-2013, 02:31 PM   #5
Robznob11
Robznob11's Avatar
Originally Posted by solidaxel View Post
The 5,3 is a 2004.
definatly wont hook to valve cover lol! But i guess if you had an intake with the purge valve behind the tb you could remove that and tap that hole. But if yours has the port in back id use it caus the barb is made for it.
LED TAILS
Old 09-10-2013, 02:39 PM   #6
solidaxel
solidaxel's Avatar
Thanks.
The manifold end of the PCV hose, not the valve cover!!
LS 3 4L70E
Old 09-10-2013, 02:55 PM   #7
Robznob11
Robznob11's Avatar
Hee hee! I gotcha lol theres always a wise guy and he usually sticks his foot in his mouth lol when i get to the house ill check the pt # on that barb and post it up if no one has by then.
LED TAILS
Old 09-10-2013, 06:06 PM   #8
83_shortwide
12559760
Double check me on that
Bo
'83 C10, LQ4, 4L80E
83_shortwide is offline   Reply With Quote
Old 09-10-2013, 07:15 PM   #9
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
This is 12559760
1/2 Nipple.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-11-2013, 01:18 AM   #10
solidaxel
solidaxel's Avatar
Does that replace the plug in the left rear of the phelem.
I will take both numbers to the dealer and see what he puts on the counter.
I also need vacuum for the HVAC, Will a "T" work here also
LS 3 4L70E
Old 09-11-2013, 10:49 AM   #11
ls1nova71
ls1nova71's Avatar
Yes, The nipple replaces the plug. There's a red plastic piece that you pushin on while pulling out the plug. As for the A/C, there is a fitting on the right side of the intake that you can break a little tab off of and hook the HVAC hose to it. Post #204 of the build thread of my rusty '71 in my sig has pics if you're not sure what I'm talking about.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html
5.3 swap into my RUSTY '71 C10
http://ls1tech.com/forums/conversion...71-c-10-a.html
ls1nova71 is offline   Reply With Quote
Old 09-11-2013, 03:39 PM   #12
solidaxel
solidaxel's Avatar
Thanks, that helps (#204), I would never thought of breaking something to find a port!
The red push pull plug?
What part is removed?
I will try and push & pull !!
LS 3 4L70E
Old 09-11-2013, 05:48 PM   #13
ls1nova71
ls1nova71's Avatar
When you pull on the plug the red part will try to come with it and not allow the plug to come out, take a small screwdriver and push the red part back in while still pulling the plug. Its really easy once you try it.
Old 09-11-2013, 07:18 PM   #14
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
There is another plug on some of the hydroboost trucks, but it still looks like a plastic vacuum plug. (just not red iirc). I couldn't find the number but I sent TruckDude off looking for it.
Old 09-11-2013, 11:42 PM   #15
solidaxel
solidaxel's Avatar
You were right...............push the red sleeve ,and pull the black plug out!!!
Ordered the part number from the local Chevy dealer, $8.11 with tax
...........Next item on the list!!!!
When I run out of things to do I am going back and read your build, I guess I should have already read it, because of all the questions you could have answered. Nice work
Thanks for the help
LS 3 4L70E
