Old 07-07-2003, 03:15 PM   #1
messed up c-10
RHCP afficianado
messed up c-10's Avatar
Block Casting Numbers
Is there an easy to get these with the engine in the truck?
~Ryan~
89 S-10 Blazer with a 4.3L
96 Ford Crown Vic P71 4.6L V8. This car rocks.
Here are some links to some good music.
Jack Johnson
Donavon Frankenreiter
messed up c-10 is offline   Reply With Quote
Old 07-08-2003, 03:00 AM   #2
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
After you have it clean really good. Wire brush it if possible to get all the caked on goo off. You can use a mirror, you can also goto wally world (Walmart) and get some play doh, silly putty, or aluminum foil. You can use them to get the imprint of the block. Some numbers maybe harder to read like 8s and such but that's why you need the surface to be really clean.
Other place is right under the alternator where the metal gas line comes up from the fuel pump. There is a pad on the block in front of the cylinder head. Might wanna take the alternator off if its still on there. There will be some numbers and letters. I haven't a clue how to figure those out. Looks like Geek to me. I haven't found anything to tell me how to read it or understand it. But that is the 2 places I know of on a sbc.
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 07-08-2003, 11:34 AM   #3
boataddict26
Other place is right under the alternator where the metal gas line comes up from the fuel pump. There is a pad on the block in front of the cylinder head. Might wanna take the alternator off if its still on there. There will be some numbers and letters. I haven't a clue how to figure those out. Looks like Geek to me. I haven't found anything to tell me how to read it or understand it. But that is the 2 places I know of on a sbc. [/B][/QUOTE]
Look in the LMC catalog. Also, go to the post that says: Help Identifiying Engine Or something like that. There is a link in there that will help you with that.
1978 Chevy C10 Currently under resto.
350 Getting face lift. .060, JEpistons, Modify heads. More will come with money.
boataddict26 is offline   Reply With Quote
Old 07-08-2003, 11:36 AM   #4
boataddict26
Need Help W/Engine Identification!!
It is on the second page of the Message Board.
Old 07-08-2003, 05:22 PM   #5
blazer-k5
blazer-k5's Avatar
http://www.mortec.com/castnum.htm when you do figure out the # this sit might be usefull to ya
No trees were killed to send this note but a large number of electrons were terribly inconvenienced.
AKA. RABIDJOE... if you have to ask you prob don't want to know. Ive had my shots *dont worry*
1960 235 4SPD C30
blazer-k5 is offline   Reply With Quote
