Old 09-10-2013, 03:07 PM   #1
bigmac73
bigmac73's Avatar
flexplate gaps?
when installing my new transmission i noticed that there is about 3/8 or more gap between the flex plate and the converter, I usually use flat washers to shim it up when I bolt them together, should I use fly wheel shims?
And what is the normal gap between the flex plate and converter I don't want to pull it forward to much or cause my flex plate to warp tighten it down?
168 tooth fly wheel, TH350 tranny
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 09-10-2013, 03:33 PM   #2
geezer#99
geezer#99's Avatar
Re: flexplate gaps?
If the torque convertor is seated into the pump it will sit about that far from the flexplate. Slide it ahead and bolt it on. No washers allowed unless you like fried pumps, warped flex plates and strange vibrations.
Old 09-10-2013, 05:27 PM   #3
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: flexplate gaps?
x2
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
Old 09-10-2013, 07:55 PM   #4
67 chevelle
67 chevelle's Avatar
Re: flexplate gaps?
without that space the "flexplate" will not flex you will burn up your trany pump in short order if you shim it tight
67 chevelle is offline   Reply With Quote
Old 09-10-2013, 08:13 PM   #5
bigmac73
bigmac73's Avatar
Re: flexplate gaps?
http://atfspeed.com/component/conten...tallation.html
(STEP 7: After the transmission housing bolts are tight, check to see if the converter can turn freely (except Ford applications with studs). Push the converter into the transmission as far as possible. Using a ruler or scale, check the distance between the converter pad and the flexplate. Pull the converter forward a minimum of 1/8 of an inch, maximum 3/16 inch. Using the flat washers, remove any additional space between the converter and flexplate. NOTE: In case of Ford applications with studs, measure from end of stud to flexplate. Tighten converter nuts and measure again. The difference should be within the tolerance.)
this what i used when i installed the last one , and in the past i had a turbo 400 on another chevy and had to use flat washers as well then
Mike
Old 09-10-2013, 08:17 PM   #6
Ol Blue K20
Re: flexplate gaps?
I just called my tranny guy and he laughed hard..Don't do the washers
Dale
Old 09-10-2013, 08:18 PM   #7
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: flexplate gaps?
Looks like an ATS specific application. I still wouldn't use them.
I've never had to use any washers with any converters I've installed in TH350's. From 4,000 RPM race converters, to bone stockers. Pull 'em up to the plate and bolt them to it.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-10-2013, 09:32 PM   #8
clinebarger
Re: flexplate gaps?
1/4" to 3/8" is normal, If it's 7/16".....Shim to 1/4".
Do Not use flat washers, There are special Shim Washers...(Wilwood caliper shims work well, Pressure plate shims also)
Running 1/8" is TOO close!!
clinebarger is offline   Reply With Quote
