Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 09-10-2013, 05:01 PM   #1
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Wanted Fire Extinguisher Bracket
Looking for a Fire Extinguisher Bracket like the one in the photo. It has a cup at the bottom that should make it easy to identify.
Old 09-11-2013, 01:04 AM   #2
burbluv
burbluv's Avatar
Re: Wanted Fire Extinguisher Bracket
Did you buy the extinguisher that was just on eBay?
burbluv is offline   Reply With Quote
Old 09-11-2013, 01:29 PM   #3
aerotruk63
aerotruk63's Avatar
Yes, it doesn't look like it comes with the bracket, so now I have to find one. GM obviously didn't manufacture the extinguisher and have put out some inquiries into who did. Were you able to use those hubcaps I sent you?
Old 09-17-2013, 05:50 PM   #4
jonzcustomshop
1961 crewcab
jonzcustomshop's Avatar
is there a better pic you can get? a couple of my trucks have ext/ brackets, none had the gm bottle, but one of the brackets might be right??
Old 09-28-2013, 08:27 AM   #5
aerotruk63
aerotruk63's Avatar
That's the best picture I can find Jon. The accessory installation manual does not list it, guess it would install wherever you wanted. It's 3 " diameter at the base and the strap would be 9" above the base. Interestingly enough I just noticed there are rounded base and flat base extinguishers with the same font. Mine has a flat base to it.
Numbers stamped into the top.
ICC-9 FM inside of diamond shape B inside of a circle 57 8-61
Couple of months ago there was a guy on ebay with the red tag he reproduced.
1964 Accessories Advertisment.
1964/65 GMC accessories manual. I know at some point they made a different bracket and changed the font similar to the square GM we knew since 66.
New font photo no cup on the bottom of the bracket.
Old 09-28-2013, 10:20 AM   #6
burbluv
burbluv's Avatar
Hey Aerotruk notice how there are two different extinguishers. One with a longer wrap around description (the first one) and the shorter wrap around description (last smaller picture). Does anyone know which is for a 62? They both list the same part number 985592.
Old 09-28-2013, 11:24 PM   #7
aerotruk63
aerotruk63's Avatar
The last small photo ( 1966 ) has the same part number as the earlier fire extinguisher but a smaller label with a different GM font. The extinguisher I have was built I believe on the 8th month of 1961.
There are other GM products that the part number remained the same though the part itself changed. I have a dash fan that was nos same part number but instead of a metal cage it had a plastic one with a different crest in the center than the earlier version.
Old 09-28-2013, 11:31 PM   #8
burbluv
burbluv's Avatar
So in a perfect world I want to find a larger label one for my 62 right? Thanks for the info
Old 09-29-2013, 07:33 AM   #9
aerotruk63
aerotruk63's Avatar
That's right, the larger label would be correct.
This is getting even more confusing now.
The very first photo in the first post, courtesy of DocRebuild, shows an early GM font with a cup and bright strap.
The first picture in the series above, post 5, for 1964 Accessories shows a bracket with a cup on the bottom and bright strap, but I can't see if the extinguisher has a round or square bottom.
The second photo shows an extinguisher with a round bottom with no cup with a bright strap and fork at the neck.
Third photo, from the 1963 Chevrolet Custom Accessories book shows a square bottom with a forked top and bright strap.
Fourth photo, 1964 and 1965 GMC Accessory Book has a fork and a full length black strap, square bottom on the extinguisher.
Fifth photo, courtesy of DocRebuild, extinguisher has a round bottom and I guessing that's the new font in 1966, bright strap with no cup .
The very first photo in the first post, courtesy of DocRebuild, shows an early GM font with a cup and bright strap, I assume a round bottom , no fork at the neck?.
Old 09-30-2013, 09:58 AM   #10
1963c-10
1963c-10's Avatar
Hey aero...I have one of those small litter containers in fawn in the top corner of the GM advertising if we need it for pics on the factory accessories thread.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-30-2013, 11:39 PM   #11
1966burb
1966burb's Avatar
I have collected vintage fire equipment for years. I have lots of early GENERAL Pyrene fire extinguishers all with rounded bottom and rounded brackets. A rounded bracket would not be used with a flat bottom extinguisher. I will check my collection of brackets tomorrow and see if I have a correct one for you. Jim
1966burb is offline   Reply With Quote
Old 10-02-2013, 08:05 PM   #12
aerotruk63
aerotruk63's Avatar
1 1/8" inner fork dimension.
Looks like there might be a series of dimples on the thumb latch.
Old 10-03-2013, 12:09 AM   #13
1966burb
1966burb's Avatar
Found this one im my old stash. More modern ones I have, have a red strap. This one has 1 1/8 fork. Yours for free if you are interested. Just cover the shipping. Jim
Old 10-04-2013, 06:59 PM   #14
aerotruk63
aerotruk63's Avatar
From the pictures above pictures it looks like the whole bracket is a bright finish. Shoot me a pm 1966burb with shipping charges and how to send you some cash.
Old 10-04-2013, 08:24 PM   #15
l79m20
Saw one at the local farm store 5.99 stainless strap metal bracket painted black, look about the right size. strap is toward the top but could easily be moved anywhere with pop rivet.
l79m20 is offline   Reply With Quote
Old 10-06-2013, 10:05 AM   #16
1966burb
1966burb's Avatar
Let me check and see if I have an all bright one in stock. j
Old 10-06-2013, 10:35 AM   #17
aerotruk63
aerotruk63's Avatar
Yeah well I'm not so bright at most times, My shipping address is:
Norman Meloche
35 Joseph Meloche
St. Stanislas de Kostka, Quebec
J0S 1W0
CANADA
Old 10-06-2013, 11:23 PM   #18
GMCNUT
GMCNUT's Avatar
GM used many suppliers for ancillary accessory production, and remember - at the time no one cared what style the bracket was, so whatever was available at the time was what was sold or produced. No show judge on the face of the planet will ever ding you on the painted / bright finish or style of your bracket, and neither will any truck enthusiasts....its not worth driving yourself crazy over
GMCNUT is offline   Reply With Quote
Old 10-07-2013, 06:57 AM   #19
aerotruk63
aerotruk63's Avatar
I don't have to drive myself crazy, I'm already there.
I just like finding out as much info and detail that I can. That's why this forum is so great when we can have information from many knowledgeable people such as yourself contributing. Thank you. The worse judge of my truck is myself , though what others think of the truck is just an added bonus, good or bad.
