Old 09-10-2013, 05:13 PM   #1
Paul Frog
Paul Frog's Avatar
Pulling hair out over wiring!
I have a 80 2 wheel drive, that's got a wiring issue bad. Gotta use another truck to start it. Once started its fine, but don't shut it off. It will not start or even attempt to turn over. So, I took my little meter and unplugged the battery checked my fuses. Found a short in the horn fuse. Would that really cause this hard short? The book that I have is junk for wiring we know the type, Haynes! What else does the horn tie into? My dome light wont come on with the fuse pulled. I just don't believe that a horn will cause this much problem. Any advice from anybody will help out tremendously!
Paul Frog is offline   Reply With Quote
Old 09-10-2013, 06:09 PM   #2
walkerb
walkerb's Avatar
Re: Pulling hair out over wiring!
How are the grounds? Clean? Battery and core support I would check. Engine to cab strap to.
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 09-10-2013, 06:39 PM   #3
Paul Frog
Paul Frog's Avatar
I will triple check again. I always seem to miss something now and again. Might get a buddy to go over it. Sometimes a new set of eyes will help.
Old 09-10-2013, 06:47 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
Member hatzie has a lot of diagrams for wiring
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 09-10-2013, 08:13 PM   #5
mongoose
mongoose's Avatar
is the battery good?
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
