![]() Join Date: Jan 2001
Howell fuel injection question
I'm installing the Howell fuel injection system in my truck. I have an Edelbrock Performer manifold and a Mallory Unilite distributor with vacuum advance. My questions for anyone who has done this conversion are : where can I get the vacuum feed for the MAP sensor ? Is it ok to make a T with the PCV valve ? There are two ports on the front of the throttle body, which one connects to the vacuum advance on the distributor ? Can I use the other for the MAP sensor ?
Any help would be very much appreciated. Bernie
Bernie |
Re: Howell fuel injection question
Needs a dedicated manifold vacuum source, Can be any port BELOW the throttle blades. The throttle body probably has a ported vacuum & manifold vacuum sources. The one that's lower would most likely be manifold vacuum.
![]() Join Date: Mar 2007
If your ECM is going to control timing you will need to lock down your advance plate so it doesn't move. No need for the vacuum advance. I have installed a TBI on my Blazer it runs great.
1968 SWB "Little White Truck" 1972 LWB LS 4l80 "Plain Jane!!" |
