09-10-2013, 07:56 PM | #1 |
Leaf spring shackle pin bolts and a lathe
When removing the rear end, I somehow misplaced one of the bolts that hold the shackle pins in place for the rear leaf springs. Six are needed and I came up with 5. So, I broke out my trusty LMC catalog and found that they could be ordered for about $6 and shipped for another $8. Or there-abouts. I could drive down and pick them up but I didn't need to go to that area for any other reason and its about a 2 hour drive.
But I do have a lathe and a 1/2" bolt I cut the head off of for some reason or other. First I checked to make sure this bolt wasn't hardened. Nope, a file cuts it easily. I'm not a machinist but here is how I did it. I miked (I could have used calipers, but a micrometer feels more machinistismo) the original and turned the bolt down to the larger diameter. I then miked the threaded section and turned it down. The threads are 5/16-24. So, I set up the gears for 24 tpi (cutting edge lathe don't need no quick change gearbox) and cut the threads so that the nut threaded on smoothly. I took a file (don't know if it was a bastard or not 'cause I never met its mother or father) and cut the flat so that it closely assumed the shape of the original. $1,800 - $14 = $1,786 I'll have this lathe paid off in no time flat. Dave, slowly starting to work on the Big Red Dog. |
09-10-2013, 08:15 PM | #2 |
Check The Champ, Demonstrator
Re: Leaf spring shackle pin bolts and a lathe
That turned out great, gotta love when something turns out that well.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
09-10-2013, 09:01 PM | #3 |
You're way ahead of the game. I guarantee the part you made fit's better than the LMC version. I bought one from LMC, luckily I found the one I misplaced and the LMC one was tossed.
09-10-2013, 11:23 PM | #4 |
aerotruk63
Yeah one win every now and then goes a long way. bhc41051 If I had known, I could have ordered a complete set from Eaton when I ordered the bushings. I didn't find out I was missing one until months later. Well, now. Dave. |
09-11-2013, 05:18 AM | #5 |
And the humor is spot on...nothing like amortizing the infrastructure! And, no Chinese Laborors starved due to the making of this new part or thread!
09-11-2013, 09:13 AM | #6 | |
Well, in all honesty, the blue towel was probably made somewhere other than the US. But I did recycle! Yup, Logan/Wards 11" Dave. |
