Mean Green
16 volt battery and alternator
Is the 16 volt a better set up than spending the big money on these high dollar alternator that put out 180-200 amps at low speed idle?https://www.dcpowerinc.com/ or HO alternators
I run a electric fuel pump, water pump and electric fan. At idle the alternator will barely charge when the electric fan kicks on and it lowers the the engine RPM so much it almost makes the motor die. I have the correct diameter pulley on it and its a 150-180 amp set up. What do you guys run for a charging set up? Thanks. Posted via Mobile Device
427 SBC 683HP & 590ftlbsTRQ @ fly wheel. 60'-1.38 1/4-10.43 MPH-124.6 New ET current 4/2019 AKA MEAN GREEN. Last edited by 68 C-10 KID; 09-10-2013 at 08:56 PM. |
| Bookmarks |
