Old 09-11-2013, 12:12 PM   #1
5spd540
ac issue
A good friend of mine has a 2001 z71 and the ac quit all the sudden if you and any idea please let me know
5spd540 is offline   Reply With Quote
Old 09-11-2013, 01:32 PM   #2
5spd540
Re: ac issue
There are no leaks
Old 09-11-2013, 02:43 PM   #3
MadManAndrew
Re: ac issue
What the hell are the symptoms? Blowing but not cold? Not blowing at all? If it's blowing but not cold is the compressor coming on? How do you know there aren't any leaks? What is the low side pressure?
1955 Chevy 3600 http://67-72chevytrucks.com/vboard/s...61#post8589061
MadManAndrew is offline   Reply With Quote
Old 09-11-2013, 06:03 PM   #4
5spd540
Re: ac issue
its blowing the compressor is not coming on. He put a electric fan on it and then the ac quit working along with the switch for the 4wd
Old 09-11-2013, 08:48 PM   #5
hugger6933
Re: ac issue
Do you mean he added an electric fan and in doing so the a/c quit working along with the 4x4 switch? I am sorry,I own a shop and I often ask some question around the horn trying to get to where I am going, talking it out is key no matter if it is with your customer your buddies or your wife. A lot of troubles could be avoided by clear comunication. Jim
hugger6933 is offline   Reply With Quote
Old 09-11-2013, 11:08 PM   #6
MadManAndrew
Re: ac issue
Pull the plug off the compressor and check the voltage across it with the AC on. Also, what are the details of the fan install? You would think that might be helpful if all this happened right after. These additional symptoms and probable causes are pertinent information when trying to diagnose. You can't just say "Hey my ac quit working what happened" and expect us to tell you.
Old 09-12-2013, 11:06 AM   #7
5spd540
Re: ac issue
Yes he hooked up the fan then the other stuff quit
Old 09-21-2013, 04:52 PM   #8
5spd540
Re: ac issue
Update. I found that the compressor has no power. I also found a ton of fuses blown that was the issue with the 4wd. The relay on the drivers fender only has power on one terminal. Correct me if I am wrong but shouldn't have power on 2 legs?
