Old 09-11-2013, 01:59 PM   #1
JustJeff79
1st post: Why won't anyone work on my truck?
Been lurking here for a while and I've learned many things thanks to this great forum.
Last year I picked up this 67 small window.
Minimal rust, 350 engine, 4 speed (originally a 6 cylinder automatic truck).
I was so busy looking for rust, I didn't notice the frame was bent.
The truck drives straight and I believe the damage is only up front (Back lines up perfect).
You can see everything is pushed towards the passenger side (about 2 inches) and the left is slightly lower.
The buckle in the frame is about 8 inches back. Everything else straight.
I've taken it to four local shops and this is what I've been told.
1. Body shop: "I can heat it up and put it the frame machine. But you'll have to get behind the insurance claims I have coming in". (still haven't heard back a month later)
2. Craigslist mechanic: "Yeah, I can torch it and bang it out" (I understand this can work, but the guy seemed shady and didn't seem to know much about these trucks)
3. Full service auto shop with several C-10's out front: "Nah man, can't fix that for you, it's a safety hazard". (This one surprised me)
4. Body shop #2: " We can fix that, but the whole front end needs to be replaced as well, you should just take that home and bang it out with a sledge hammer. Save yourself some money". (The whole front end thing threw me, I'm replacing the core support, but the whole front end? because of a tweek in the frame?)
Frustrated, I went home and took off the bumper, measured everything up and started in with the sledge hammer.
Then the damn frame split!
Needless to say, what I thought wouldn't work, didn't.
How do I get this frame right?
Should I weld the split?
Should I start the search for a new frame?
Anyone in southern middle Tennessee you can steer me towards?
All and any input is much appreciated.
JustJeff79 is offline   Reply With Quote
Old 09-11-2013, 02:05 PM   #2
71K20chevy
71K20chevy's Avatar
Re: 1st post: Why won't anyone work on my truck?
You could weld it...it's not really an important part anyway. My truck has a bad split in the same spot, it hasn't fallen apart yet.
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 09-11-2013, 02:27 PM   #3
leddzepp
Moderator
leddzepp's Avatar
I would just leave it alone and drive it if you aren't building a show truck.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 09-11-2013, 02:46 PM   #4
geezer#99
geezer#99's Avatar
NIce truck!!
If the frame horn is bent that much how did the bumper fit so good?
Old 09-11-2013, 02:58 PM   #5
JustJeff79
Originally Posted by geezer#99 View Post
NIce truck!!
Thank you sir!
The pic of the whole truck is kind of an optical illusion.
The bumper is very tight on the driver's side, and sticks out a couple of inches on the passenger side.
If you look closely, you can see it descend as it reaches the passenger side (though hard to see from the angle of the photo).
It seems the frame took a front/side impact at some point in it's life.
Old 09-11-2013, 03:08 PM   #6
geezer#99
geezer#99's Avatar
The only good way to check it is on a frame rack. Go to the first guy on your list or find an alignment shop with a rack.
Old 09-11-2013, 03:10 PM   #7
Andy4639
Old member
Andy4639's Avatar
Cool Re: 1st post: Why won't anyone work on my truck?
Live with it, I do! Mine is the same way. Not worth all the fuss. Spend the time righting the stuff u can. Like said u can weld it but it want make much differance.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-11-2013, 03:37 PM   #8
jeffahart
jeffahart's Avatar
I usually use a big crescent wrench to bend that area at the tip of the horn.
Just tap the frame around the buckle with a single jack sledge, then push pull the tip of the horn with a crescent until it looks close to the other side. Then measure distance between horns. spread the horns apart or bring together as needed. I think if you get it close you will be fine.
The problem will then be, the bumper was bent along with the horns. So, it may not fit w/o tweaking and maybe serious tweaking. And now you are in limbo where the old bumper will not fit nor will a new one.
Maybe do a little at a time and keep re-bolting the bumper on so you can slowly keep it tweaked into fit with the horn adjustment.
Good luck.
jeffahart is offline   Reply With Quote
Old 09-11-2013, 03:42 PM   #9
hounddogs!
Restoring it $200 at a time...
hounddogs!'s Avatar
I absolutely do not understand this. Is insurance money greener than eveyones else's?
\\rant off\\
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society
'68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327.
DD '09 Pilot
Weekender '65 Skylark 300-4V-4 speed
Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine.
Son's '04 F250 SuperCab 6.0
hounddogs! is offline   Reply With Quote
Old 09-11-2013, 04:02 PM   #10
JustJeff79
Good luck.
Thanks for the advice. I've pounded the buckle from the inside and the horn from the outside. It moved about a 1/4 inch before the frame split. So I stopped.
The bumper isn't the original. I don't think much of the truck is. Seems to be several different trucks put together.
Old 09-11-2013, 04:16 PM   #11
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Cracks in that area are common, before you weld take a drill bit and drill through the frame at the end of the crack. The round hole will prevent the crack from propagating further. Then use a grinding wheel to bevel out the inside of the crack, then fill the hole and bevel with weld.
You could keep looking around at body shops, it doesn't look too severe, and shouldn't take long to fix on a frame table.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 09-11-2013, 04:19 PM   #12
leddzepp
Moderator
leddzepp's Avatar
\\rant off\\
Insurance companies bring repeat business, and will always take precedence.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-11-2013, 04:35 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Mine is tweeked a bit too... been driving the snot out of it for 7 years with no issues. Toss the bumper back on and have fun with your truck.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 09-11-2013, 04:46 PM   #14
tommys72
tommys72's Avatar
Ahhh, leave it the way it is and sell it to me. .. that would be your best bet. ..lol... seriously though, nice truck
United States Marine Corps 2000-2011
Iraq and Afghanistan veteran
Just living life now and enjoying it and my wife, daughter and son
tommys72 is offline   Reply With Quote
Old 09-11-2013, 05:00 PM   #15
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
I hope I never have to ask someone to work on my truck or car ,,, feel for ya ,, nice truck !
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 09-11-2013, 05:38 PM   #16
TBONE1964
Cluster King
TBONE1964's Avatar
\\rant off\\
The funny thing is insurance companies don't fix anything anymore. If has a dent bigger than the size of a soft ball, they total it. I am not sure what these body shops are fixing. Every car you see at an action now has a salvage title because the insurance company wrote it up as totaled.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
