Old 09-11-2013, 02:31 PM   #1
HSRACER
HSRACER's Avatar
Exclamation Amp gauge works backwards!
My factory dash 69 was completely reworked by the previous owner. The amp gauge shows discharge while driving down the road. I put my volt meter on while idling and shows 13.5 volts while the gauge is showing discharge.
Is it possible the gauge could have been wired backwards somehow? I know the plug into the stock dash is still in place to power the cluster so I wold like to know the gauge wiring so I can check proper continuity.
Any help is appreciated! Thanks
HSRACER
Slammed 53 5 window
Blown/Bagged 54 Pickup
Patinaed 67 LS stepside
Supercharged 67 Nova
Bagged 69 Suburban Turbo'ed 5.3 LS
HSRACER is offline   Reply With Quote
Old 09-11-2013, 03:39 PM   #2
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Amp gauge works backwards!
Your gauge plug wiring should look like this.
Name:  cluster connector with gauges.jpg
The two wires at 1 and 12 are the gauge wires and they originate in the engine compartment. shown here.
The first diagram shows the wires as both being black with a brown stripe and the second show them as being a solid black and a black with white stripe. You may have something similar or different,
Turn the key on without starting the engine and watch the gauge while you turn on the lights and step on the brakes. The gauge should move to the left
showing discharge. When you start the engine the gauge should move to the right showing charge. If it works the opposite then chances are the 1 and 12 wires are reversed in the gauge plug. These wires are both positive so use care if you switch them. The fuses shown are 4 amp fuses to protect the gauge from overvoltage. They are inside little football shaped rubber housings
located by the battery junction on the right passenger fender and by the voltage regulator on the left side of the radiator.
The dash cluster is wired as shown and the wires at 1 and 12 are shown going to the ammeter.
Name:  Dash  Layout Final.jpg
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 09-11-2013, 04:29 PM   #3
HSRACER
HSRACER's Avatar
Thanks. This truck has an aftermarket wiring harness and the factory fuses are all gone. The diagram you provided will be very beneficial as I check voltages. So do you see any issues with just switching terminal one and twelve?
HSRACER
Slammed 53 5 window
Old 09-11-2013, 07:10 PM   #4
68gmsee
Active Member
68gmsee's Avatar
Shouldn't have issues. Amps are read in series to a 12 volt supply so switching the wires won't hurt the amp gauge and probably will fix your problem.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
