Old 09-11-2013, 04:14 PM   #1
Jdbfish
Best rear gears for 700r4
What is the best rear end to run behind a stock 350 with a 700r4 auto? Most of my driving will be at hwy speeds. Will a 3.08 be ok?
Jdbfish is offline   Reply With Quote
Old 09-11-2013, 04:26 PM   #2
steelhorse
steelhorse's Avatar
Re: Best rear gears for 700r4
Should be fine. The 700r4 has a real low first gear so take off shouldn't be too bad. Depending upon your tire size you may actually end up with a lower rpm at highway speeds than you would like. I say try it then adjust if you aren't happy.
steelhorse is offline   Reply With Quote
Old 09-11-2013, 04:28 PM   #3
Dova
Dova's Avatar
From what i've seen people on the site using, a lot of them do not like the 3.08 because of to sluggish on the highway. Most seem to use 3.73's
Dova is offline   Reply With Quote
Old 09-11-2013, 04:30 PM   #4
cdowns
cdowns's Avatar
most guys over the years have had very bad results and an actual decrease in fuel milage when useing a 700r4 and 308 rear gears// where the guys with the 700r4 and the 373 get best results and fuel milage increases
Old 09-11-2013, 04:43 PM   #5
MARKDTN
3.42 is the best ratio with tall tires for a mixed use. If you are pulling more, then maybe 3.73.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 09-11-2013, 05:14 PM   #6
slow-1
slow-1's Avatar
I have 3.08 gears, 700r4 trans, 255/70/15 tires, perfect from 60 mph up.
Around 55mph it feels like it is lugging a bit but my "RV" cam doesn't care.
I like it, I can't say they are the "best" gears as I haven't run it with any others to compare.
My mileage went from 11 mpg with the saginaw 3 speed to around 18 mpg overall (that was with 235/70/15 tires, haven't checked it since I upgraded).
Can't speak for others though.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 09-11-2013, 05:30 PM   #7
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
X 2 especially with a 28/29 inch tire.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 09-11-2013, 06:03 PM   #8
WIDESIDE72
WIDESIDE72's Avatar
3.73
WIDESIDE72 is offline   Reply With Quote
Old 09-11-2013, 06:41 PM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Best rear gears for 700r4
I run the 700 r4 with 4:10's and get 16-18 MPG depending on how fast I'm running. At Highway speed (70MPH) I'm turning around 2300RPM's.
I like the way it runs and it performs well for a 305!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 09-11-2013, 07:11 PM   #10
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Literally over 75 percent of the 2wd 88-98 trucks that were V8 and 700r4/4L60/e overdrive equipped came stock with 3.42 gears. Perfect ratio. GM got it right on that one.
Old 09-11-2013, 07:44 PM   #11
1968ratrod
1968ratrod's Avatar
I am currently running 3.08's and my truck don't like it at anything below 60 mph, I am in the process of switching to 3.73 .
1965 Chevy Suburban
2003 Chevrolet S10
2011 Harley Streetglide
1968ratrod is offline   Reply With Quote
Old 09-11-2013, 07:53 PM   #12
Jdbfish
Is there a stock 3:42 6 lug rearend option for a 70 model? Thought only 3.08, 3.73 or 4.10 were available
Old 09-11-2013, 08:21 PM   #13
tlcrz1972
tlcrz1972's Avatar
350 FI / 4L60E / 3.08's / 30x9.5 tires great setup; take off is not a problem and at speed it works perfectly even with 6000 to 7000 lbs in tow in OD in the hills.
cruising speed of 70 MPH, rpm's are only 1650-1700 and fuel mileage is well above 17 MPG (unloaded)
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more.
1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE)
1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI ,
1972 Chevrolet 3/4 ton suburban future project
1972 Chevrolet 3/4 ton p/u maybe a project one day
1966 Toyota Landcruiser my playtoy
tlcrz1972 is offline   Reply With Quote
Old 09-11-2013, 08:27 PM   #14
Fitz
A 3.08 will lug around town with that trans. TX had it right when he said 3.48 is optimal but failing that try a 3.73. Below are the RPM vs MPH for a 700 R4 for the 3.08, 3.48 and 3.73 in that order
Fitz is offline   Reply With Quote
Old 09-11-2013, 10:08 PM   #15
Eddie H.
Eddie H.'s Avatar
My son's 71 GMC with a 350, 700R4, and 3.08 gears is a bit sluggish for my liking. We will probably change to 3.73 sometime in the future.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 09-11-2013, 10:30 PM   #16
LockDoc
The Older Generation
LockDoc's Avatar
I changed the 3.08 to a 3.73 in the '69 Suburban. Made all the difference in the world.... it has a 2004r OD trans in it. Averaged 16 mpg on a 550 mi round trip to Kansas City, MO last weekend. I'm lovin' it...
LockDoc
Leon
Old 09-11-2013, 10:34 PM   #17
lha1992
lha1992's Avatar
My '89 C1500 has a 350 FI, 700R4 and 3.08s in the rear with 31in tires on it.
Thinking of going to a 3.73 since its got a bigger tire on it.
lha1992 is offline   Reply With Quote
Old 09-11-2013, 10:35 PM   #18
midnight rambler
midnight rambler's Avatar
Great information here my 700r should be installed by the time i get back from vacation.
midnight rambler is offline   Reply With Quote
Old 09-11-2013, 10:45 PM   #19
kaycee
kaycee's Avatar
3;73 gears ,28" tall tires nasty 327 / 4L60 street or highway I freeking love it
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 09-11-2013, 11:55 PM   #20
LockDoc
LockDoc's Avatar
My Burb has 31's on it too.
LockDoc
Leon
Old 09-12-2013, 06:26 AM   #21
darkhorse970
darkhorse970's Avatar
I have a 700r4 and 3.73s in my '63. It is a good combo with my 275/60/15s, but I think that 3.42 would be a good combo too. I went from 4.11 to 3.73, so the difference was significant. I like the gearing currently for quick take offs, and crusing rpm (~2300 @ 70).
I am considering a Monster 700r4/3.42s in my '68 w/ my 427 BBC. It should have plenty of torque to feel strong on take off.
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 09-12-2013, 07:00 AM   #22
That's it ^
That's the sweet spot. 3.42s weren't offered in these trucks back when needs (for the most part) were different from now. 3.08-3.73 leaves a wide gap and 3.42s fill it perfectly. It's a great ratio for hiway with or without O/D,yet spill has grunt. I'm building my '67 with an M22 and 3.42s and it's a hiway machine who's bed will get used. When I can afford it,a Gear Vendors will go in. This ratio will work either way.
I know this is manual/no overdrive talk,but this give perspective on the the range of ratios we're talking. The truck I helped my neighbor with ('68 SWB) has a 4spd and he didn't want it to suck the gas too hard. He went with 3.08s...hated it. Changed to 3.42s and it's good. Now he's got a ZZ3 in there and realizes he just wants a hot rod and,no matter what,it's going to like gas and he's not going to commute or travel in it. So,he's wanting 3.73s now for bit more grunt. If it was me,now,I'd be swappin' 4.11s!!
Old 09-12-2013, 10:31 AM   #23
LockDoc
LockDoc's Avatar
So basically the only way to get 3.42's is to use the later, wider rear end and weld on new mounting pads?
LockDoc
Leon
Old 09-12-2013, 10:36 AM   #24
Keith Seymore
Keith Seymore's Avatar
3.73's are perfect.
The overdrive in the trans brings it back as though they are 3.42's.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 09-12-2013, 10:36 AM   #25
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
Does it hurt a 700r4 to drive it in third gear and only manually shift to OD when necessary?
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
