Old 07-07-2003, 05:44 PM   #1
Ron
Ron's Avatar
Where does your exhaust exit?
I'm putting a new exhaust system on one of my trucks (69 LWB). I'm using 2 1/2 aluminumized pipe. I'd like some ideas on where to exit the exhaust. I'm thinking about behind the rear wheel near the back corner of the truck. I have a welded in rear roll pan. Pictures would be nice. Thanks
'69 SWB
'76 International "Terra"
"Hooked on holiday beer"
Ron is offline   Reply With Quote
Old 07-07-2003, 05:48 PM   #2
FILICE72C10
FILICE72C10's Avatar
my truck
here mine
72 C10 SWB
02 Subaru WRX
95 Nissan 240SX
FILICE72C10 is offline   Reply With Quote
Old 07-07-2003, 06:42 PM   #3
COBALT
COBALT's Avatar
Straight out the back duel 2 1/2 pipes with angled chrome tips. if you imagine the picture above the pipes coming straight back without bending down and outward it would look like my truck.
'69 3/4 ton C20 2wd-350ci/TH400
'69 3/4 ton Custom 20 2wd-350ci/4sp Manual
'99 2wd 5.7 Chevy Tahoe
Seattle, WA.
COBALT is offline   Reply With Quote
Old 07-07-2003, 06:43 PM   #4
oldsub86
I went with an exit just ahead of the rear wheel on the driver's side (inline 6 but you could easily put both out one side or one out each side). It made for a simple pipe given that I didn't have to concern myself with going over the back axle.
1968 Chevy - 292 with a powerglide
oldsub86 is offline   Reply With Quote
Old 07-07-2003, 06:51 PM   #5
SEVEND2
SEVEND2's Avatar
Heres Mine
I am running Dual exhaust 2 1/2" alum coated pipes with Magnaflow mufflers, and Chrome tips, with out a (H) pipe, It dumps infront of the tires. Sounds Great not to Loud in the cab, but does get heads turned!!!!
With a 1972 Chevy Custom-10 Long bed w/350cid th350, (under-construction).
Progress on truck so far (follow link):
http://67-72chevytrucks.com/vboard/s...ad.php?t=51051
and stage 2
http://67-72chevytrucks.com/vboard/s...ad.php?t=58132
~ "Why couldn't you have just put the bunny back in the box?" ~
SEVEND2 is offline   Reply With Quote
Old 07-07-2003, 07:06 PM   #6
crazy longhorn
Fabricate till you "puke"
I run 2 1/2" in, & 2 1/4" out of the muffs. Hooker headers, 40s flows(blowmasters),H pipe, & the tail pipes exit through the rear bumper. Not too bad in the truck, 6th gear keeps the revs down on the highway.......otherwise, those 2 chamber flows are right on the resonance point on the hyway with 4.10 gears @ cruise speed. Its loud as he!! when I stand on the throttle tho. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 07-07-2003, 07:10 PM   #7
GreenMystChevy
I had a thought on something I'd like to do if I ever get to that stage.
Would it be possible, or even look good, to do have duals exiting in the rear, coming out below the rear corners of the bumper at a very steep angle? Have them not quite pointing straight down. not turndowns, but but more of a 45 degree angle out and 45 degrees down with 3 1/2 tips. Tuck 'em up in there so that you only see a couple inches of the tips.
Really hard to explain and not even sure if it's possible.
Jeremy
'71 C-10
'72 GMC K2500
'72 Nova (Dad's)
'70 Chevelle SS
'55 Sedan Delivery
Attempting to build up this here 4x4...make her real tall and purty...well, maybe just tall
GreenMystChevy is offline   Reply With Quote
Old 07-07-2003, 07:41 PM   #8
Red68
Red68's Avatar
I have seen them exit out the back corners and turn down at an angle where they are hardly noticed, like on an older chevelle. The tips were cut at an angle and the pipes had a 45 deg bend. Looks really cool. Probably expensive unless you know someone that owns an exhaust shop or you do it yourself.
1968 C10 LWB 327 bored 40 over, RHS heads, KB pistons, Eagle rods, Edlebrock carb & intake
1968 C10 flatbed 307 w/ 4 spd manual (dads old ride)
1936 1/2 tn pickup, 400sb 350 turbo (partially restored)
1949 1/2 tn, needs complete restore (future project)
1969 Chevy impala 4 dr no post (wifes future car)
2010 GMC Serria 4x4 crew, leveling kit
Red68 is offline   Reply With Quote
Old 07-07-2003, 08:24 PM   #9
Piston
Piston's Avatar
Red68, thats how I have mine cut. It's alot of work to get the bends right but I like the look alot. I had a friend that owns a exhaust shop do it... cost 100.00 for tailpipes using 2.5" aluminized pipe.
Depends on the weather for how my exhaust exits lol. Spring/summer/fall I run dumped 40's under the bed before the axle. During the winter I run the tailpipes I mentioned before.
Piston is offline   Reply With Quote
Old 07-07-2003, 08:54 PM   #10
71MoneyPit
MPG...hmm..more like GPM
71MoneyPit's Avatar
here's mine,
its dual 2 1/2 inch aluminized pipe to dual 2 1/2" V-Force Mufflers that exit straight under the bed
(yes it's LOUD!)
(Looking for 67-72 shortwide or shortstep bed)
71 C-10, 500ci of tire shredding Caddy torque, th400, 12 bolt w/Powertrax Lock-Right. Bald Rear Tires
85 Toyota 4x4- 22r 4-banger, 5 speed, I can actually AFFORD to drive this one.
71MoneyPit is offline   Reply With Quote
Old 07-07-2003, 09:28 PM   #11
jef5150
Inline 69
jef5150's Avatar
nascar style?
not mine,,,,i wish!!!!
jef5150 is offline   Reply With Quote
Old 07-07-2003, 09:36 PM   #12
Kid
Kid's Avatar
personally, I prefere the exhaust be heard and not seen.
Kid is offline   Reply With Quote
Old 07-07-2003, 09:37 PM   #13
Kid
Kid's Avatar
a shot from below
Old 07-07-2003, 10:42 PM   #14
1972ChevyGuy
1972ChevyGuy's Avatar
Anybody running that cool titanium exhaust like the new vettes are? That stuff looks AWESOME! Too bad the price isnt awesome
1972ChevyGuy is offline   Reply With Quote
Old 07-08-2003, 01:20 AM   #15
krazy_texan
krazy_texan's Avatar
i am running what everybody around here calls "REDNECK PIPES", they are 3inch stainless steel pipe, 12 inch glass packs and 4 inch angle cut tips in front of the tires. really loud not good if you carry many passengers seeing as you have to scream or use sign language but it does turn heads
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 07-08-2003, 03:39 PM   #16
Earl Junior
Cadillac power
Earl Junior's Avatar
I'm using 2 inch aluminized tubing into and out of Flowmaster 40 series mufflers. If I had to do it over again I'd use 2 1/2 inch tubing and turn the mufflers up-and-down so that they tuck better. I like the setup, but don't like always being able to see it. I definitely don't like scraping in driveways.
Just for the record, if I'm down to my last potato, I'm not sharing it with a guy who wants to kill me so he can get a better supply of virgins in paradise. That lesson is a little thing I call Economics 101, infidel style.
--Scott Adams author of Dilbert
Earl Junior is offline   Reply With Quote
Old 07-08-2003, 03:40 PM   #17
Earl Junior
Cadillac power
second pic
Old 07-08-2003, 03:40 PM   #18
Earl Junior
Cadillac power
third pic
Old 07-08-2003, 09:46 PM   #19
Chevy409
Giddy up giddy up...
Chevy409's Avatar
2.5 inch into some burnt out glasspacks and 4.5 inch tractor trailer pipes exiting out the sides in front of the rear tires... sets car alarms off
72 with 69 grille and custom 73-87 stepside. BIG BLOCK 409, SM465, NP205, 3/4 axles slung under a 5" lift, 3"bodylift, 112" frame, and 35inch Pro Comp X-terrains... "BUILT NOT BOUGHT" Here's the site...
Chevy409 is offline   Reply With Quote
Old 07-09-2003, 12:50 AM   #20
miket
miket's Avatar
My 3 inch system exits just like in Kid's picture.
FocuzTech Performance
Evergreen Protective Coatings
Gatorhyde...the best kept secret in spray in bed lining & protection
miket is offline   Reply With Quote
Old 07-09-2003, 08:09 PM   #21
Figment412
Hey Kid, where did you get your fuel tank?
My truck will have dumps in front of the rear axle. If i was lowerd I would want dual side pipes on both sides infront of the rear tires.
Save your money and do it right the first time.
1968 GMC short bed
1972 Cab
74 SB Chevy running gear
Figment412 is offline   Reply With Quote
Old 07-09-2003, 10:31 PM   #22
73stepside
73stepside's Avatar
mine are like 71 moneypit's without the tips.
04 GMC Sierra RCSS
70 CST LWB
04 HD Sportster 1200 Custom
73stepside is offline   Reply With Quote
Old 07-09-2003, 10:53 PM   #23
Lucky59
Do you feel Lucky...?
Lucky59's Avatar
Here is mine... Hooker Headers, 2 1/4 tubing, with Flo Pros... I like how mine exit out the side, it sorta makes it look like a newer truck in some sense...
Lucky
1959 Chevy Shortbox Stepside
1969 Chevy Custom C/10
1991 S-10 Blazer Sport
2003 Dodge SX2.0 R/T
2001 Mountain Cat 800 LE
Lucky59 is offline   Reply With Quote
Old 07-09-2003, 11:23 PM   #24
Wreck
mine are just the old ramhorn exhaust manifold straight pipes with 24" glass packs and exiting straight out the back..sounds really good..not as loud as alot of trucks in my neck of the woods....anyone using those huge megaphone exhaust tips?? everybody that has a truck has those here, some are about 2 feet long and about 6" - 8" tips.
Wreck is offline   Reply With Quote
Old 07-10-2003, 03:44 AM   #25
71-longbed
Its Magically Delicious
71-longbed's Avatar
behind the back tire ..... next time i want it before the rear tires ....loud and proud
71 C10 LWB
350sbc -TH350
12 bolt 3.42 Posi
Of all my favorite things to do, The utmost is to have a brew.
My love grows for my foamy friend, with each thirst-quenching elbow bend.
Beer so frosty, smooth, and cold it's paradise pure liquid gold.
Yes beer means many things to me that's all for now cus I gotta pee.
71-longbed is offline   Reply With Quote
