Old 09-12-2013, 06:03 PM   #1
67 Burb
67 Burb's Avatar
67 Burb door panel removal
I simply want to lubricate the lock mechanisms and latch release etc. inside the doors on my 67 suburban. I have removed the 4 screws along the bottom of the panel as well as the arm rest and the handles. I expected the panel to just slip out from under the chrome strip at the top of the panel, but it won't. Before I damage something, I would like to know the correct way to get the panel off.
Bob
67 Burb is offline   Reply With Quote
Old 09-12-2013, 06:25 PM   #2
budnikguy
budnikguy's Avatar
Re: 67 Burb door panel removal
Gentle prying with a putty knife along the bottom and side will do it...
budnikguy is offline   Reply With Quote
Old 09-12-2013, 06:45 PM   #3
67 Burb
67 Burb's Avatar
It's loose all along the bottom and up the sides, but doesn't want to come out from under the chrome strip at the top. Are there screws under the chrome strip, or does it just pull out?
Bob
Old 09-12-2013, 06:53 PM   #4
budnikguy
budnikguy's Avatar
There are screw that hold the chrome strip in place, but you slide the door panel down and out of it. Holding both sides, left and right, gently pull down on each side back and forth until it lets go....a lot of times it is just the vinyl has been sitting in that chrome channel so long it is a bit sticky..
Old 09-12-2013, 06:57 PM   #5
67 Burb
67 Burb's Avatar
OK, budnikguy. Thanks, I will give it a try.
Bob
Old 09-13-2013, 10:40 PM   #6
67 Burb
67 Burb's Avatar
Got it. The panel was stuck under that chrome strip so solid that I really thought it was screwed on. But I did manage to pull it out.
Thanks,
Bob
Old 09-13-2013, 11:21 PM   #7
vectorit
What?
vectorit's Avatar
Glad the forum was able to help you out!
We're all here to help each other by sharing our experience.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 09-13-2013, 11:36 PM   #8
budnikguy
budnikguy's Avatar
Great to hear it broke loose for ya......
