What Hump?
Were their any options like this or a 4x4 missing one of the 4's?
http://phoenix.craigslist.org/evl/cto/4061159678.html
Lil red 86 c-10 99 Sub 78 Camper Special w/ 454 |
Re: Never seen this before straight axel front end on a 73
I have never seen that as an option....
Interesting...hard to see the detail...did someone sub a piece of tubing for the axle housing and just weld the original ends on. You could make an neat 1/4 mile truck..or just a pro street for Libby,MT hot August nights Start with a Blazer chassis...do the straight axle conversion with tubing...use a set back 502 and a TH400 Just like a tri 5 Chevy with a straight axle and flip front |
Not factory. Looks like a 4wd that someone converted. It would be intereting to see the kingpins.
1987 2 ton ![]() 1982 250/TH350 beater in progressDad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrappingPlus a mess o' tractors |
Looks like a 2wd cab with a low hump in it.
Not sure if this is a possibility, I know on the Dodge side if you ordered a cab and chassis 3500 it came with a solid tube axle. Did Chevy do the same around this time period? Maybe they pulled that.
Something that may or may not mean anything. Look at the frame and bottom of the motor. Not any rust hardly. That axle though has alot of surface rust. I agree, not original.
Trevor 74 C20...work in progress. 04 Saturn Ion...Daily Driver |
Sway bar not hooked up, steering stabilizer shock not hooked up......don't think it's factory.
- Jeff 89' K5 Blazer, 2.5" lift, 35" tires ![]() 04' GMC Yukon XL, 3/4 ton, 8.1L |
Never seen anything like that before.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
#8 | |
Another Day, Another Dollar
I really wanna build a 5 ton like that!
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square"
Location: On the banks of the Clackamas River, Eagle CreeK Oregon
The question is.... Why would someone do this ? I can only imagine how it must handle with this front end set up
![]() Join Date: Feb 2013
I think it looks cool, would make a interesting Gasser style project.
I would have to agree, it would not handle at all, but it would be worth it in my opinion. -Sam
1987 Chevy R30 CC 454/4spd Work Truck 1979 Chevy K10 SWB 350/4spd/NP205, 1979 Chevy C10 LWB 350/TH350 Project 1981 Chevy K30 350/Th400/NP205 1986 Chevy K30 CUCV 6.2L/TH400/NP208 |
I wonder if its a military contract truck of some sort --- the green oxide paint with red interior is a common military truck color scheme ---- some national guard unit could have specce'd that thing that way for use on an airport or something
but truthfully, IDK why
Are you retired too? Nonsense! I'm in my prime |
wants a bit much for it dont ya think?
"DON'T TOUCH THE TRIM!!"-Early Kyler |
#13 |
GoatLube Experss
![]() Join Date: Oct 2009
if it's rust free (Arizona) would be a decent price. easily convert'd to 4X4 or 2 wheel drive.
as far as military spec'd ...I doubt it. every one I ever seen/work'd on was 1 ton long bed , 24V and had "black out lights" . it's possible but not likely.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn. '87 R30 dually 454/TH400 '85 1/2 ton CCSB '92 S10 350/350 '84 MonteCarlo 383/PG/9"ford '78 Malibu wagon 350/350 '78 Cutlass (project family car) '96 S10 Jimmy (Moma's) |
#14 |
links gone but ih had solid axle 2wds so idk chevy may had a heavy 1 ton idk.
#15 |
It was a short bed truck it looked home made but good home made tho.
#16 |
prob was that or they used a ih or jeep dummy axle. im pretty sure its a direct swap seeing how both 4wd had the dana.
| Bookmarks |
