Old 09-12-2013, 07:21 PM   #1
rdrnation
69 gmc a.c.
I have a 69 gmc with factory a.c., everything appears to be there. I have not tried to charge it. What steps and in what order should i try to get it going? should i buy some freon and just try to charge it and see if it works and go from there? thanks
rdrnation is offline   Reply With Quote
Old 09-12-2013, 07:28 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: 69 gmc a.c.
The first thing I would do is take it and have a vacuum put on the system. If the system will not hold a vacuum then it has a leak.
If it has a leak then you will need to find it. The best way is with dye. If you don't have the tools or equipment it would be best to take it to a reputable shop that can service it.
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com
I am also a dealer for Counterpart for gauge cluster parts only.
Also see my facebook page, CG&C
TBONE1964 is offline   Reply With Quote
Old 09-12-2013, 07:33 PM   #3
Eddie H.
Eddie H.'s Avatar
Re: 69 gmc a.c.
First, put some gauges on it and see if it has anything in the system.
If it does, turn it on and see if you can get the compressor clutch to engage.
If there is no pressure in the system, hook up an a/c vacuum pump, pull it down to 28 inches and and see if it will hold vacuum. If not, then you need to start tracking down the source of the leak before wasting expensive R12.
"Negative people always seem to have a problem for every solution"
Eddie H. is offline   Reply With Quote
Old 09-12-2013, 07:35 PM   #4
rdrnation
Re: 69 gmc a.c.
ok i will do that, thanks
Old 09-12-2013, 07:35 PM   #5
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: 69 gmc a.c.
It may not pull down to 28 inches if there is a leak
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 09-12-2013, 07:40 PM   #6
Eddie H.
Eddie H.'s Avatar
Re: 69 gmc a.c.
Yep, that's right, if the leak is big enough, the vacuum pump can't pull it down that far, but the larger the leak, the easier they are to find.
Old 09-12-2013, 07:46 PM   #7
Ol Blue K20
Re: 69 gmc a.c.
True very true...
Dale
