Old 09-12-2013, 08:47 PM   #1
crazy longhorn
Fabricate till you "puke"
LS Longhorn, game just started
The old LS is across the rails of the 69....fit is good! I used the stock I 6 stands, but slotted them forward, & added 5/8" in front. With the Carshop inc plates, she came spot on the measure, with the trans cross member moved 1" forward. The Hooker street rod shorties fit great...(better than 1" clearance, tween the 1st tube & the stand. The old booger is mounted to a 55 chev (car bell, & fastened to a 6 spd Richmond box. Specs on the engine...stock, 138,000 rounds....top fresh (pressure test/surface/grind & set of LS6 springs). She has the GMPP streetrod pan (H-3 hummer), & the fit is good, for the cash spent.....she could easy run the camero , or caddy pan tho ...pan hangs about 3/4" below the crossmember? Not an issue on my ride, but for the "slammer crowd", you will probably want the camero pan? I know you guys want pics....I am a little computer "challenged", but will try to get one of the boys out to shoot some pics Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 09-12-2013, 11:49 PM   #2
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: LS Longhorn, game just started
send pictures, and stop spelling Camaro with an E.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-13-2013, 04:27 AM   #3
crazy longhorn
...it is a bit funny, I was the spelling champ in grade school, but that was about 50 yrs ago Will try to get pics...the week end will be tied, planting the old stroker, in little bros S-10. We are still looking at a little track time, before the season is done! Longhorn
