Old 09-12-2013, 09:14 PM   #1
TommyDuncan
62' 8 lug spindle/brake swap?
I tried looking through the huge brake thread but I never really found a specific answer to my questions.
Is there a drop spindle available for my 62' 8 lug ūton GMC?
Could I keep the factory drum brakes or would I need to do a disc brake swap? I WANT TO STAY 8 LUG!
Any help would be great!
TommyDuncan is offline   Reply With Quote
Old 09-12-2013, 09:40 PM   #2
63burban
Chevy addict
Re: 62' 8 lug spindle/brake swap?
I have never seen any 8 lug drop spindles other than dually drop spindles, you would have to switch to disc brakes but 3/4 ton hubs should fit 1 ton spindles
63burban is offline   Reply With Quote
Old 09-12-2013, 10:53 PM   #3
endlessearth
endlessearth's Avatar
I am new to the scene but I have a C20 and, from my research, it seems fairly certain that if you want to lose the inches you have to give up some lugs. On the upside, your wheel choices vastly increase.
endlessearth is offline   Reply With Quote
Old 09-12-2013, 11:49 PM   #4
TommyDuncan
Performance Online makes them in 8 lug for 63 up. Does anyone know if they are adaptable to a 62? Maybe I can find that info in the brake thread?
Old 09-13-2013, 05:45 AM   #5
tincan1966
tincan1966's Avatar
What I think, and cannot prove , is that the '60-'62 share a unique lower ball joint, so there is not an interchange to allow the use of later spindles. All disc brake and power steering trucks had larger ball joint shafts.
Like to convert a '63-72, you just change out the ball joints to a '73-'87 and use the appropriate spindle.
tincan1966 is offline   Reply With Quote
Old 09-13-2013, 07:44 AM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Couldnt you change the lower ( AND UPPER) A-arms also? just to accomidate the drop spindles
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-13-2013, 09:08 AM   #7
19666Trucker
19666Trucker's Avatar
Gmcjerry I think make a spindle kit check brothers I saw some where for 999 you get whole front end kit, hub to hub
19666Trucker is offline   Reply With Quote
Old 09-13-2013, 09:18 AM   #8
TommyDuncan
since this is a torsion bar front end I would have to change everything, including the cross member. I don't want to modify it that much.
I will check Brothers. Never heard of GMC Jerry's. I will look for it. Thanks!
Old 09-13-2013, 09:36 AM   #9
Clyde65
Clyde65's Avatar
Ok Tom, forgot about it being a TB front. I've never had one or worked on one..yet!
Clyde65
Rebuild of Clyde
support our troops!
Old 09-13-2013, 09:58 AM   #10
TommyDuncan
It's all good! I appreciate any help I get. I think I will adjust the torsions down a little. That might do the job. The power drums stop it just fine. Maybe I'm over thinking things?
Old 09-13-2013, 01:14 PM   #11
Clyde65
Clyde65's Avatar
I've done that A LOT, good to step back and take another look sometimes.
Clyde65
Rebuild of Clyde
support our troops!
Old 09-13-2013, 03:25 PM   #12
1963c-10
1963c-10's Avatar
Might consider a crossmember swap to something newer...the 60-62 guys do them all the time on the 1/2 tons
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 09-14-2013, 07:24 PM   #13
TommyDuncan
Posted via Mobile DeviceI turned the torsion down and went with the smaller Jeep springs in the back... 4-5" in the rear and I'm guessing 3" in the front.
