09-13-2013, 12:16 AM | #1 |
C30 Crew cab question
I picked up a decent 3/4 ton crew cab and wanted to lower it with 5x5 wheels in place of the 8 lugs.
Can I swap out the front engine crossmember w/ a 1/2 ton 73-87 as long as I use all the steering components (center link/pitman/idler/tie rods)? Thanks in advance for any input!
Brian XNGH ECV Chapter 58 1972 Jimmy / Blazer Project 2wd 1974 Chevy Crew Cab Shorty |
09-13-2013, 01:04 AM | #2 |
Re: C30 Crew cab question
You probably can just do the lower arms, spindles, and brakes. I think. Some one else will chime in
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
09-13-2013, 07:34 AM | #3 | |
67-72 parts collector,…
Early Classics also make a 3/4-ton to 1/2-ton conversion spindle. This allows you to bolt a 1/2-ton rotor and caliper to your existing a-arms and steering. Super easy swap for the front. No crossmember to remove. No steering to change. That's the way I would do it! Especially since you want to lower it anyway. Look here: www.earlyclassic.com.
09-13-2013, 08:39 AM | #4 |
Yes, 1/2 ton x-members will swap directly in place of the C20/30 stuff or you can keep the x-member in place & just swap the parts to the existing x-member.
09-13-2013, 09:05 AM | #5 | |
09-13-2013, 09:06 AM | #6 | |
thats just too easy!
09-13-2013, 09:28 AM | #7 | |
They call them 71-87 conversion spindles. (plus they have two other spindles for the older model C20's) But we all know they will work all the way up to the 1991 "square body" 3/4 tons and 1-tons. And they are only $299 from ECE.
04-06-2014, 08:18 PM | #8 |
I have a c30 that I plan on making 5 lug too. The ECE c20 conversion spindle will work on 1 tons?
