Old 09-13-2013, 09:47 AM   #1
77ChevySharkBite
77ChevySharkBite's Avatar
taking off front clip as whole
I need your help guys!
I'm going to be hopefully getting rid of my old 305/th350 combo today, my question is. How do you pull off the front clip of our truck as a whole piece I'm thinking it's those 4 bolts total. 2 at the top of where the fenders are and then 2 at the bottom kind of where the cab sits. Are those the only bolts that are holding it in? What else will I have to unplug etc to take it off as well.
Thanks fellas you guys are awesome!!!
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 09-13-2013, 09:56 AM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: taking off front clip as whole
Subbed, I need this info myself.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 09-13-2013, 10:14 AM   #3
frog210
2 on the top by the windshield 2 between the door and the fender 2 where the cabs sits at so a total of 6 bolts for both sides, dont forget to count the shims,
The electrical connectors radiator bolts o yea the inner fender bolts that bolt to the fire wall I think that should be it, whatever is left will be noticeable and be able to pull out easily
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 09-13-2013, 10:25 AM   #4
77ChevySharkBite
Alright cool thanks Frog!! I appreciate it I figured it would be pretty easy to pull just wanted to double check to make sure it's all simple.
Korwin
Old 09-13-2013, 10:29 AM   #5
cochino12
It followed me home?
cochino12's Avatar
there are also bolts on the radiator support, iirc they just pull out from the bottom though
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 09-13-2013, 10:30 AM   #6
frog210
Idk depending on your brake lines you might have to remove the inner fender or remove the whole fender, I was trying to install a 87 front clip onto my 74 and well I removed the whole drivers fender because of my brake lines
San Antonio, TEXAS
-Frog
Old 09-13-2013, 10:30 AM   #7
J Knight
J Knight's Avatar
Take the bumper and front wheels off too for clearance. If you have decent paint, tape the front edge of the door and rear edge of fender to protect the paint.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 09-13-2013, 10:33 AM   #8
frog210
I agree with bumper, I did it no problem with my tires 31in tires on, it gave me something to sit the fender on when I was doing this by myself lol
San Antonio, TEXAS
-Frog
Old 09-13-2013, 12:24 PM   #9
tex_waco_usmc
Project Heaven in my 67!!!
Use a cherry picker and a system of ratchet straps and it will make the lifting and moving so much easier, trust me I know this to be truth as I just did this on my daughters truck by myself! Was easy-peasy!!!
Name:  Placement of front clip.jpg
tex_waco_usmc is offline   Reply With Quote
Old 09-13-2013, 05:04 PM   #10
77ChevySharkBite
Great!! Thanks for all the info and heads up fellas I really appreciate it more than you know! It's just primered so no issues with scratching paint or anything of that nature also no worries with a bumper as I don't have one .
Thank you guys i'll let you know how it goes!
Korwin
