Old 09-13-2013, 05:49 PM   #1
cb1965
cb1965's Avatar
5.3 swap into 65 advice.
I can get a 2001 suburban cheap. It has high mileage, 180,xxx. Is it worth it to swap the engine and transmission into a 65? Is the mileage a deal braker or are these engines good for a lot more. I think I could also use the front seats but not sure. Any input and advice greatly appreciated. Thanks
'66 chevy lwb c10
'65 chevy lwb c20
cb1965 is offline   Reply With Quote
Old 09-13-2013, 06:02 PM   #2
tinydb84
tinydb84's Avatar
Re: 5.3 swap into 65 advice.
How cheap? I have seen them run upwards of 300k. I believe they are factory rated to 200k. You could sell the burb to the junkyard after to recoup some of the cost.
Im in SJ too. What part are you in?
David
Instagram: myfabguy
Old 09-13-2013, 07:16 PM   #3
donthekawguy
donthekawguy's Avatar
Check some of the ls forums and find out the weak spots on the 5.3 and while it's out fix them. With a cam, headers and reflash those motors are good for around 400 hp. I have one in my garage that my son picked up for $200. He's tearing it down to see if there are any issues and just doing a basic rebuild on it.
66 shorty
donthekawguy is offline   Reply With Quote
Old 09-13-2013, 08:29 PM   #4
cb1965
cb1965's Avatar
Well it's my uncle that has it and we still haven't worked out the details but it might be a trade. I have a Buick that I don't really use and he seemed interested in it. I'm on Capitol and berryessa off 680. If they can reach the 300k mark in good order I might just do it. Ill do some more digging and see what I come up with.
'66 chevy lwb c10
'65 chevy lwb c20
Old 09-13-2013, 09:04 PM   #5
65 wonton
Go to the LSx swap section of this board, LSswap.com and some of the LS sites. Rumor has it that if not abused these engines last a long time (250-300K). There is a lot more to canabilize from the donor than the engine. Wiring, guages, senders, brakes, rear end, tranny, interior, A/C, wiring, steering column...
Scrap what you don't use.
I'm going the route of a '98 T/A into a 66.
Dave.
65 wonton is offline   Reply With Quote
Old 09-13-2013, 11:08 PM   #6
tinydb84
tinydb84's Avatar
Im doing an LS swap in my 75. I have a 66 too. If I finish first (at this rate...never) Ill lend you a hand
David
Instagram: myfabguy
Old 09-14-2013, 01:13 AM   #7
cb1965
cb1965's Avatar
Sounds good. Maybe I can drop by to check out your progress sometime and lend a hand if you need.
'66 chevy lwb c10
'65 chevy lwb c20
Old 09-14-2013, 09:20 AM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
180K is a little high but if your only doing a cruiser and you know the motor's history, then go for it.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
